Old 05-06-11, 01:09 PM   #1
MJC-DEV
MJC-DEV's Avatar
Default Goodridge Oil Cooler Pipe available
First pictures of the new Goodridge replacement oil cooler pipe set. These are based on my old SK6 pipes that I lent to Goodridge to draw up into a retail kit. As you can see, they have used blue alloy banjo fittings.
Two things, I haven't fitted them yet but they look to be spot on compared to the original pipes and I don't know the retail price or what's included in the full retail kit - Give them a ring on the UK, Exeter, number if you are interested.
SV_OP0 by MJC-DEV, on Flickr
SV_OP2 by MJC-DEV, on Flickr
SV_OP1 by MJC-DEV, on Flickr
MJC-DEV is offline   Reply With Quote
Old 05-06-11, 03:58 PM   #2
Huwbee
Default Re: Goodridge Oil Cooler Pipe available
They look very nice indeed makes me wish I had an oil cooler !!!!
Old 05-06-11, 05:50 PM   #3
muzikill
muzikill's Avatar
they look ok. i would have liked the banjos to be black at one end and silver the other. then they would blend in. has anyone ever looked into making their own btw?
Old 05-06-11, 06:55 PM   #4
MJC-DEV
MJC-DEV's Avatar
I think a few guys have had some made by hydraulic suppliers such as Pirtek. But I think these only come with zinc plated banjos - but most likely cheaper than Goodridge.
Pays yours money etc...
Old 05-06-11, 06:59 PM   #5
toxic
Very neat, hope you put up pics when they're fitted.
Goodridge braided oil cooler lines ordered. MJC-DEV SV Talk, Tuning & Tweaking 7 16-04-12 12:57 PM
Pointy short Oil cooler pipe. MJC-DEV For Sale - SV's and SV related items 0 17-04-11 12:18 PM
K3-K8 RH oil cooler pipe DavieSV Stuff Wanted 6 10-08-10 08:46 AM
Oil cooler pipe torque settings. rowdy SV Talk, Tuning & Tweaking 4 07-03-09 11:10 PM
Oil cooler questions..pipe fittings svrash SV Talk, Tuning & Tweaking 1 17-08-07 07:47 AM
