Old 22-06-11, 08:41 AM   #1
Murph
Default 2 or 3 brake lines?
Could someone please explain any advantages/disadvantages of running the 2 line "race" setup rather then the standard 3 lines using braided brake lines.
On a 2002 sv650s if that makes any difference?
Thanks
Old 22-06-11, 09:11 AM   #2
martin15s
Default Re: 2 or 3 brake lines?
I find that 2 lines help eliminate air locks and are so much quicker and easier to bleed.
Old 22-06-11, 09:14 AM   #3
Chris Bird
+1
Also, limits the chance of the hose rubbing your on your hugger and marking it.
Old 22-06-11, 09:32 AM   #4
Murph
Thanks for the help!
Old 22-06-11, 10:05 AM   #5
johnnyrod
johnnyrod's Avatar
Cheaper, usually you pay per line not for the length
Old 22-06-11, 12:02 PM   #6
Another vote for the 2 line "race" setup here
Old 22-06-11, 12:03 PM   #7
hardhat_harry
Deffo 2
Old 22-06-11, 07:03 PM   #8
MJC-DEV
MJC-DEV's Avatar
2 lines are cheaper, 3 lines if you want the 'standard' look.
MJC-DEV is offline   Reply With Quote
Old 24-06-11, 02:27 PM   #9
jambo
jambo's Avatar
The shortest ammount of line you can use, and thus the most "direct" system is one line down to the right caliper and a short one from there up and over the mudguard to the left caliper. This isn't a "race" setup as it's not allowed by ACU rules, but I rather like it.
The 3 line setup is very neat but it does cost more.
The 2 line "race" setup is perfectly fine if it's fitted carefully. Often the lines are not routed very carefully and rub on bits of plastic, and generally look untidy to my eyes.
Jambo
Old 24-06-11, 08:35 PM   #10
daved407
Cheaper as you pay per banjo union. So its 4 as opposed to 6. Agree on the bleeding too
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Hel Brake Lines Andy Lewis Hardware 1 22-09-10 01:20 PM
HEL brake lines RingDing For Sale - SV's and SV related items 9 29-05-10 09:17 PM
brake lines. x Silver x SV Talk, Tuning & Tweaking 10 03-01-09 09:11 PM
SV brake lines svrash For Sale - SV's and SV related items 1 27-02-06 10:42 PM
