Old 22-06-11, 07:42 PM   #1
Speedy
Default Goodridge brake hose outer diameter?
As the title really....
Anyone know what the OD is on their brake lines???
Thanks in advance!!
Old 24-06-11, 11:34 AM   #2
MJC-DEV
MJC-DEV's Avatar
Default Re: Goodridge brake hose outer diameter?
8mm according to my steel rule
MJC-DEV is offline   Reply With Quote
Old 24-06-11, 05:57 PM   #3
Speedy
That's great! Many thanks!
Old 25-06-11, 07:52 AM   #4
muzikill
muzikill's Avatar
you making them? ive found the banjos to be the most expensive part
Old 25-06-11, 07:00 PM   #5
Speedy
No, just been waiting for the correct ones to arrive, (no thanks to a certain Motorcycle & Parts company!) and needed to order some hose separators.
Goodridge or Hel Braided Brake lines? edmc SV Talk, Tuning & Tweaking 35 19-03-11 11:36 AM
Goodridge Brake Hoses 21QUEST For Sale - SV's and SV related items 2 03-01-11 05:54 PM
Goodridge Braided Hose Sets SV-net SV Talk, Tuning & Tweaking 15 25-07-08 11:29 PM
EBC Pro-Lite brake discs and Goodridge GH brake pads r4ce_e3nd For Sale - SV's and SV related items 7 14-04-07 07:37 PM
goodridge brake hoses kwak zzr SV Talk, Tuning & Tweaking 0 22-10-06 05:09 PM
