Old 24-06-11, 04:44 PM   #1
Default Battery terminal repair?
The lead terminals on the sv's battery are knackered. Is there anywhere you can get them replaced or repaired?
Old 24-06-11, 05:38 PM   #2
Holdup
Default Re: Battery terminal repair
http://www.ronayers.com/Fiche/TypeID...SV650_SV650S)_
Old 24-06-11, 11:25 PM   #3
Breakers mate or as HU's linked
Old 24-06-11, 11:44 PM   #4
It's the terminal on the battery, not the wiring loom. Trying to avoid buying a new battery
Old 25-06-11, 12:24 AM   #5
Ah right
What states it in?
Its a
moment
Old 25-06-11, 08:05 AM   #6
muzikill
muzikill's Avatar
can you drill a new hole in and nut and bolt ? or clamp? . btw im interested to know how its fookt?
Old 25-06-11, 10:44 AM   #7
Not sure how well it would drill. It's like the lead has slowly spread apart
Old 25-06-11, 12:41 PM   #8
Id get a file and remove the excess metal, bend the terminal straight.
Get a small piece of steel or brass, bend it over the ok terminal and drill it to the right size hole.
Mate looking at that you may have a elecrical issue as that has had massive heat over it
Old 25-06-11, 01:15 PM   #9
I think i might struggle to get the loom connector over another bit of metal
Na its always been that funny shape. I think its just the pressure of the bolt that has made it seperate
Old 25-06-11, 01:39 PM   #10
what you got running over the battery?
Never thought about using another fuse board?
battery terminal bolts Cam_73 SV Talk, Tuning & Tweaking 2 08-12-09 07:59 PM
Battery Terminal Bolts JediGoat SV Talk, Tuning & Tweaking 6 12-05-08 12:03 PM
Terminal 5.... DanDare Idle Banter 16 29-03-08 10:40 AM
Heathrow - terminal 1 duffbattye Bikes - Talk & Issues 3 14-11-06 01:02 PM
Positive battery terminal needed TK2216UKG Stuff Wanted 7 23-03-06 04:44 PM
