Old 26-06-11, 06:31 PM   #1
AirArmed
Default K3 650 wont rev up?
when i start the bike it idols a little low and then when i try and bring up the revs it cuts out like its starved of fuel. i had ridden it for 45 mins then got off and left it in the sun for 2 hours then went back to it and thats when the problem arrose, never had any issues before. its got half a tank of fuel in it still.
has anyone else had this problem?
if so any suggestions?
thanks
Old 26-06-11, 06:37 PM   #2
kaimera
Default Re: K3 650 wont rev up?
adjust the idle speed to 1300rpm - thats what she should idle at
and check the TPS
Old 26-06-11, 08:04 PM   #3
AirArmed
what is the tps?
Old 26-06-11, 08:33 PM   #4
ImplodedHamster
throttle position sensor
(dont know what it does though )
Old 26-06-11, 08:57 PM   #5
kaimera
lol my bad.
throttle position sensor.
here explains it brilliantly and how to adjust it- http://forums.sv650.org/showthread.php?t=55459
defo check the idle speed tho; i had similar probs with my k4 sv, she was idling at about 900rpm and under heavy revving it would just die.
Old 26-06-11, 11:43 PM   #6
AirArmed
oh right thanks. what would cause the idol to suddely drop away like that?
Old 30-06-11, 01:00 PM   #7
ImplodedHamster
not a clue, but with a bump someone more inteligent should find it and comment
wont go above 1st jourdain Bikes - Talk & Issues 13 02-01-11 05:45 PM
sv 650 wont start jaepres SV Talk, Tuning & Tweaking 2 14-07-08 06:35 AM
still here but wont be around - Quiff Wichard Idle Banter 2 25-02-08 03:56 PM
I wont do that again ! Banus Idle Banter 12 01-04-07 08:56 PM
Well..........will you...........wont you??????? Stig Soho Massive 39 04-02-05 07:17 PM
