Old 27-06-11, 09:59 PM   #1
hardhat_harry
Default Identify these wires cheers
Currently building the bucket,
Can anyone identify where these wires go?
and
Btw the bucket is only days away from being started with its rebuilt engine just needs the exhaust on and the fluids in, just charging the battery now..
It looks a bit worse for wear at the mo but its getting nearer
Old 27-06-11, 10:05 PM   #2
Default Re: Identify these wires cheers
Top single wire, oil pressure switch, RHS of oil filter.
3 wire connector, either fuel sensor or speedo sensor. If it has pink wire in it then it is speedo.
Old 27-06-11, 10:11 PM   #3
hardhat_harry
Yea I found the fuel sensor so it must be speedo sensor, thanks for that.
So where does the Neg side of the battery go?
Old 27-06-11, 10:14 PM   #4
Negative wire goes to one of casing bolts on back of motor in between motor and frame from RHS of bike. Then goes directly to battery negative, there is spade connector between fat wire and loom.
Old 27-06-11, 10:18 PM   #5
hardhat_harry
I'll have a look in the garage tomorrow, cant remember seeing a wire like that, may be missing it. I have a couple of looms so hopefully one has the wire.
Cheers Spannerman! Sir Trev SV Talk, Tuning & Tweaking 3 11-08-09 05:13 PM
Cheers Stewart !!! Cronus SV Talk, Tuning & Tweaking 1 13-07-07 08:23 AM
3 cheers I'm Back D.i.e.S.e.L Idle Banter 5 09-10-06 09:21 AM
Cheers Northwind! Saint Matt Photos 14 25-04-06 10:11 PM
