Old 28-06-11, 12:51 PM   #1
Talking silly question time
as i have never tried it, what would happen if you connected all the vacuum spigots from the TB's or carbs together using a piece of hose?
my thoughts are it would run like shizz as its pulling air from other TB's/carbs.
Old 28-06-11, 12:53 PM   #2
Milky Bar Kid
Default Re: silly question time
I have no idea but one thing I know is that the thread title fairies will DEFFO change that thread title ROFL!!
Old 28-06-11, 01:09 PM   #3
Bib try it and let us see the results
Old 28-06-11, 01:35 PM   #4
TamSV
TamSV's Avatar
I'll be surprised if anyone's tried it. Why not start a poll?
I'll vote for you running out of fuel because you've switched off the fuel tap by removing its vacuum pipe.
Old 28-06-11, 02:14 PM   #5
only on a curvy. suppose you could put a t piece in to keep the vacuum feed going to the tap.
Old 28-06-11, 11:09 PM   #6
It would probably run fine.
Old 28-06-11, 11:13 PM   #7
ThEGr33k
My map sensor does just that. A feed from each cylinder to a T connector onto the Map sensor. So id guess no difference...
Can a noob ask a silly question? Jamie Slick SV Talk, Tuning & Tweaking 32 12-05-08 11:39 AM
So then (Silly Friday question) Viney Idle Banter 34 10-11-07 02:03 AM
silly decal question _drummer_ Bikes - Talk & Issues 2 26-11-06 07:29 PM
very silly question Warren The Essex Lounge 8 29-06-05 10:51 AM
Silly Question: Metric or Standard littlemonster SV Talk, Tuning & Tweaking 14 26-05-05 03:08 PM
