Old 01-07-11, 09:20 AM   #1
muzikill
muzikill's Avatar
Default Gear indicators
Noticed that some of you guys have these fitted. Ive also noticed that a acumen loom kit is £100.00! - there are other diy kits on ebay eg.
http://shop.ebay.co.uk/i.html?_from=...All-Categories
How easy would it be to diy one rather than be properly ripped off just coz you get a loom kit with the acumen one?
Old 01-07-11, 09:24 AM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Gear indicators
I mocked one up that would have cost about £20. difficulty would have been getting the connectors to allow it to plug inline so no wiring mods needed.
There is a feed to the ECU that tells it which gear you are in based on a certain voltage per gear.
This was for a pointy.
Old 01-07-11, 09:30 AM   #3
Dicky Ticker
Gear indicator=speedo & rev counter-----why would you need anything else if you are a competent rider?
Old 01-07-11, 09:46 AM   #4
SoulKiss
SoulKiss's Avatar
Cos it iz well bling, innit.
For me it was a project to learn some more Electronics skills, hence the fact one isn't made/on my bike.
Not to say I won't make it in the future if I can source the plugs
Old 01-07-11, 02:23 PM   #5
muzikill
muzikill's Avatar
3 years off the road and keeping the revs low has made me think about it. Plus im a lazy b and a bit rubbish at remembering what gear im in until i twist the throttle. Considering how cheap you could get one of these set up i thought it was worth looking into it and seeing how acumen are in effect charging you £80 for a small wiring loom i grudge paying to be ripped off.
Micron Front Paddock stand, Arrow-style LED indicators, Chrome Eagle-Eye indicators, Rear paddock stand Aluminium bobbins for swingarm.... lucky strike For Sale - Other Bikes and General biking items 12 27-08-09 12:00 PM
curvey Gear leaver, peg bracket, indicators and left pannel. scottjames Stuff Wanted 6 19-02-08 07:31 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
