Old 26-07-11, 11:43 AM   #1
Nicky S
Nicky S's Avatar
Default Clutch Not Disengaging
UPDATE:
have done a oil & filter change and also chain adjustment. re adjusted the clutch cable at both ends and still no change but now i have noticed that the push rod that pokes out is moving when the clutch is in and out and it dose not move all the time just when ever it feels like it.
after cleaning it off i think it is bent.
The last two weeks or so when ridding my 2002 curvy, The clutch is not fully disengaging. So ridding along in first pull the clutch in and the bike still moves along. Only way i can describe it is if you were in a car pulled off then removed your feet from the clutch and the loud pedal and just let the car move along on tic over.
i have adjusted the clutch cable at the lever & engine end. Which made no difference what so ever. I have also played with the clutch release screw. Which has changed nothing. I have also cleaned all the crap out from around the front sprocket and also cleaned the push rod.
I also removed the whole clutch release assembly and cleaned and re-greased it.
but still I can get the clutch to completely cut the drive.
I have no problems changing gear. The bike has not had an oil change in over a year. Bad I know but I just haven’t had time. Also a new clutch cable about
8 – 12 months ago. Have looked over cable and it seems fine and well greased. But it was not a OEM Suzuki one I don’t think. But I can take up the slack in it.
The only outcome I can think of now is the push rod is bent,(is this a common problem) or I need new clutch plates as these ones could be worn.
also why is there a RH & LH push rod?
Last resort is taking it to a bike garage bye bye ££££ Please shower me with advice, as need the bike working asap.
cheers nicky s
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 26-07-11, 12:16 PM   #2
Nicky S
Nicky S's Avatar
Default Re: Clutch Not Disengaging
just looking at this http://forum.svrider.com/showthread.php?t=54588
3. Change the oil.
If your oil is old or has a lot of mileage on it (6 months or 3,000 miles) change it. Consider changing the filter, too. Don't overfill. (Note that if you always ride an hour or more every time you get on the bike the oil can go more than 3,000 miles, but if you don't ride much don't go more than 6 months regardless of mileage).
mabey i should change the oil and see if that makes any diffrence
Old 26-07-11, 12:17 PM   #3
timwilky
timwilky's Avatar
I know this sounds daft, but trust me,
Oil level and chain adjustment seem to have effects on the clutch drag. check both.
I have also experienced wear on the clutch plates/basket agin causing the clutch to drag rather than disengage.
Not Grumpy, opinionated.
Old 26-07-11, 12:21 PM   #4
Nicky S
Nicky S's Avatar
not daft i did think about it but did not think it would make that much diffrence but ill have a look at the oil change and the chain.
cheers
Old 26-07-11, 12:41 PM   #5
mister c
mister c's Avatar
Depends on how often you use the bike. Could be plates sticking together, maybe.
I'm having a problem with mine at the moment as it's hardly being used. When I pull it out of the shed, start her up then engage 1st gear, the bike lunges forward as iff the clutch hasn't been engaged. It then, on re starting, tries to pull forwards, but is ok after that initial stall.
Could be worth taking your clutch apart, clean the plates, treat her to new oil, adjust everything up & see how it goes
Old 26-07-11, 12:44 PM   #6
Nicky S
Nicky S's Avatar
the bike is used nearly every day. i think ill do an oil change and see where it goes from there
Old 27-07-11, 11:55 AM   #7
Nicky S
Nicky S's Avatar
Originally Posted by Nicky S View Post
UPDATE:
cheers nicky s
after all of this and nothing changing i decided to take the clutch plates out and found this.
one of the green rubber bands is broken cant find the other half
dont know if you can really see in this pic but it is also rather worn
but the 6 clutch plates seem fine. so new clutch drive plate ordered lets see if that fixes my problem.
Old 27-07-11, 12:04 PM   #8
Viney
I didnt listen to this piece of advice but i advise you to. Dont buy anything other than Suzuki own brend clutch plates. EBC ones warp or drag. I have all manner of issues with my clutch a while back, and it turned out to be worn plates, i replaced them with EBC ones and had nightmares, changing everything including the basket, bearings etc. I managed to get hold of a secondhand clutch assebly whole including Suzuki plates. Changed just the plates (not steels(done them later)) and the clutch was fine and dandy.
Now Nicky, not sure if you do a lot of Clutch up wheelies? This can notch the clutch basket quite badly and this can cause the clutch to drag as well.
So, get yourself a new set of plates, and if the steels are very blue, a new set of them as well. Oh, and dont bother changing the springs for any heavy duty ones. They make no differeence just make your clutch heavy.
Old 27-07-11, 12:08 PM   #9
muddydude
I had excatly the same problem as you.When I engaged 1st gear the bike would stall ,It was that bad..I cleaned the plates in petrol put them backtogether with new oil and its much much better..
Old 27-07-11, 12:14 PM   #10
beabert
It will be back lol
As above avoid ebc plates! they break easily.
Clutch not disengaging. 650sv SV Talk, Tuning & Tweaking 16 12-04-11 03:09 PM
Clutch not disengaging? Deano24 SV Talk, Tuning & Tweaking 5 06-11-10 05:23 PM
Clutch not disengaging Jamie_SV SV Talk, Tuning & Tweaking 5 04-04-09 06:57 PM
Clutch Not Fully Disengaging mosius SV Talk, Tuning & Tweaking 1 25-08-07 06:24 AM
Clutch not disengaging. Mesomorphman SV Talk, Tuning & Tweaking 22 19-09-06 09:40 PM
