Old 03-08-11, 08:29 PM   #1
muzikill
muzikill's Avatar
Default This months bike of the month is Sv1000 k3-k7
http://www.suzuki-gb.co.uk/bikeofthemonth/2011/august/
Thanks to bibio for pointing this out on another thread, i just noticed that a few parts in this offer are interchangeable on other models eg. sv650. It's maybe worth keeping an eye on this every month and see what cheap oem goodies come up.
For example. I bought a L/H handlebar grip £11.50 normally & £6.50 for b.o.t.m deal. The same grip goes for £15 on ebay atm.
We may find a lot of the bodywork parts and some other parts are the same for some suzukis and save some dosh on oem. You could take advantage of this to build up some spare parts.
Also if you read the small print when you create and view a voucher you will see that the offers will be honoured for 2 months from the start date instead of one.
Suzuki bike of the month Bibio Bikes - Talk & Issues 6 04-08-11 11:31 AM
This months bike of the month is Sv100 k3-k7 muzikill SV Talk, Tuning & Tweaking 2 03-08-11 09:24 PM
DRZ - Bike of the month Owenski For Sale - Other Bikes and General biking items 3 13-05-11 11:18 AM
Bike of the Month Dangerous Dave Bikes - Talk & Issues 20 20-12-08 04:53 PM
Leaving the bike for a month Rhiwbina_Squirrel Bikes - Talk & Issues 10 08-07-08 09:48 AM
