Just want to calm my nerves here. I have noticed recently when starting the bike after a night in the garage it is very rough, almost verging on sounding like it is running on one cylinder. It doesn't want to rev, and sometimes cuts out. After a few seconds (10-15) its back to normal.
Anyone else? Thanks, |
Yeah quite common, a good service normally sorts it.
Do you know when the spark plugs were last changed (if ever?) If not, that would probably the first place I would look.
sounds like a bit of dampness.. or take the spark leads off and push them back on fully.. could be loose....
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
sounds like its just warming everything up, start it up, then put your helmet and gloves on then by that time it should be nicely warmed up and good to go
Feeling a bit rough | sv_rider1990 | SV Talk, Tuning & Tweaking | 2 | 06-05-08 03:30 PM |
Now I'm not saying the Rhondda is rough, but... | arenalife | Idle Banter | 2 | 23-04-07 12:26 PM |
Sounding rough | Black widow | SV Talk, Tuning & Tweaking | 1 | 07-03-06 01:11 PM |
It could be rough! | adam | EuroTour | 6 | 12-05-05 05:53 PM |
Starting /rough running problem | Sholay | SV Talk, Tuning & Tweaking | 5 | 26-01-05 04:18 PM |
