Old 11-08-11, 10:26 AM   #1
trail guru
Default New chain & sprockets - new whining noise?
I've just fitted a new DID chain and new sprockets to my SV650S K3 and adjusted chain tension to about 25mm (manual says 20-30mm). But the bike's got a new whine.
It's more of a background whine, most noticeable at low speeds (10-40mph), is not gear specific and is loudest when under load (ie: throttling up). I have been told it's quite usual for new chains and/or drive sprockets to whine but this info is anecdotal from other bikers, not from anyone who really knows.
Oil level is OK BTW.
Old 11-08-11, 10:58 AM   #2
hongman
Default Re: New chain & sprockets - new whining noise?
Checked alignment?
Old 11-08-11, 12:09 PM   #3
trail guru
Yup. Checked alignment. Chain has a straight run through, no visible kinks etc. Sprockets are on the right way round (tooth count stamp on outside).
Old 11-08-11, 12:19 PM   #4
hongman
If you could see a visible kink in the chain I'd say there is a pretty serious problem!
I'm assuming seeing no kinks wasnt your only way of checking alignment?
I'm not going to preach here as I havent had a new chain and sprockets on my bike yet, but I'm due one now.
I'll let you know if I notice any odd sounds etc!
Old 11-08-11, 12:30 PM   #5
DJ123
DJ123's Avatar
did you torque up the sprocket bolts & rear axle up to the correct setting?
Old 11-08-11, 12:31 PM   #6
TazDaz
Did the original front sprocket have a rubber damper? Replacement non-OE front sprockets typically don't come with the rubber damper on the sprocket and I know a few folk who notice a whine after replacing and have put it down to this.
Old 11-08-11, 12:35 PM   #7
trail guru
Wheel/sprocket alignment was set using the scales on the swing-arms, first ensuring that the triangular-shaped widgets with the alignment markers were seated centrally on the axle.
I know they're a pretty crude but that's all there is. And, more anecdotal opinion from biker mates, alignment doesn't have to be spot on.
Old 11-08-11, 12:37 PM   #8
trail guru
Yup. 145Nm on the front, can't remember what the back was off the top of my head.
Old 11-08-11, 12:38 PM   #9
hongman
Aha, I have no knowledge on what mechanical knowledge you have, was basically just ensuring you weren't just eyeballing the alignment and calling it fine!
Now that has been established - next!
Old 11-08-11, 12:38 PM   #10
DJ123
DJ123's Avatar
have you checked the rear wheel bearing?
Chain and sprockets Endellion For Sale - SV's and SV related items 5 27-02-10 07:21 AM
New chain and sprockets- "whirring" noise twopots SV Talk, Tuning & Tweaking 4 20-08-09 10:55 AM
chain + sprockets? lancasterlad SV Talk, Tuning & Tweaking 2 06-08-07 08:01 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
Chain and Sprockets.... 650newb Ancillaries 3 28-07-05 05:25 PM
