Old 12-08-11, 12:17 PM   #1
carpet monster
Default I think my ignition coils are breaking down.
Can someone please tell me the symptoms of ignition coils breaking down please?
Old 14-08-11, 10:53 AM   #2
carpet monster
Default Re: I think my ignition coils are breaking down.
Guess not.
Old 15-08-11, 11:42 AM   #3
Misfire under load or any other random misfires that are hard to trace.
Old 15-08-11, 12:12 PM   #4
carpet monster
Mine cuts out intermittently at about 6500rpm... sounds about right
Old 15-08-11, 01:57 PM   #5
Scythe92
Mine ran on one cylinder, but the second would fire randomly.
Old 17-08-11, 08:15 AM   #6
NedSVS
Guess not.
I think the lack of replies is pointing to the fact that this is very rare/unlikely. Maybe the vibrations are just right at 6500rpm to affect a poor contact or breaking wire? I wouldn't be in too much of a hurry to buy replacement coils until I had done some investigating.
Old 17-08-11, 08:55 AM   #7
johnnyrod
johnnyrod's Avatar
does it happen more with a hot engine than cold?
Old 17-08-11, 09:30 AM   #8
Hardened Rider
Had this on my K6. Cutting out was intermittent to begin with, usually when hot, then the front cylinder stopped firing completely one night, ended up coming home on the rear only. If you've done the simple check first (visible plug condition) Remove the spark plug from the cylinder, keep the plug on the lead and hit the starter with the plug (spark end) pointing at the head or frame. Hold the plug by the plastic cap before you turn over. Check the condition, colour and frequency of your spark. Nice healthy spark is blue, not so good is yellow to brown.
If you deem the spark unhealthy, try another plug in good condition and repeat the process.
My spark was brown, very weak and intermittent. I bought a moulded coil, lead and cap from ebay for a fiver. Mitsubishi.
This was all great fun in the dark.
Once thing I did notice is I needed to bump start the bike after is didn't want know to from just the starter.
Good luck!
SV650(S) ignition coils + HT lead K3 K4 K5 Flameboy For Sale - SV's and SV related items 1 01-04-10 07:12 PM
K3 ignition coils/HT leads Holdup SV Talk, Tuning & Tweaking 2 08-02-10 02:53 PM
Ignition Coils - Anyone got a set? kbh Stuff Wanted 2 08-08-09 12:14 PM
ignition coils riktherider Stuff Wanted 2 18-08-08 01:40 PM
ignition coils stumpy1 SV Talk, Tuning & Tweaking 10 22-06-06 05:31 PM
