Old 23-08-11, 06:24 PM   #1
svsam
svsam's Avatar
Default front tyre issues
Im out half way through cleaning my bike as i type this.
So for a while i'v thought the front end to be a bit 'skitty' like its not quite going to stick if i ride any harder round the corners, which is odd as its only started happening since i replaced the rear tyre, prior to this its was spot on to be honest!
Now, as im cleaning her, i have a good look over the front tyre, it seems that the bit 'that isnt the centre and isnt the outside (the bit in between) has worn hell of a lot, almost no visible tread! therefore i had like a shoulder on the rims of my tyre about 1cm from the edge, all the way round, both sides.
Is this the way im riding? or the bike?
Im running pilot road ones at the moment, jacked up 45mm at the rear, and dropped about 5mm through the yokes.
Hope this makes sence......
Cheers, Sam
SL0 jack up kit-yoshimura can-tial tidy-(so far)
svsam is offline   Reply With Quote
Old 23-08-11, 06:27 PM   #2
SV Mad
Default Re: front tyre issues
Is the pressure right? Maybe needs 1 or 2 more psi.
Old 23-08-11, 06:51 PM   #3
NedSVS
Cheers, Sam
That is pretty normal front tyre wear in my experience - front tyres wear most in corners when you are leant over. This tends to lead to the wear pattern you describe and the reason it feels strange when you push the front a little harder than usual - the contact patch suddenly becomes a lot smaller when you lean a little further than usual. This is why I rarely keep a used front on when I change the rear.
Old 24-08-11, 05:43 AM   #4
Red Herring
Red Herring's Avatar
As above really, except the "skittish" feel actually comes from an increased contact patch, not a reduced one. The way the tyre wears flattens off the profile so that you end up with a V shape instead of a nice new rounded one. This means that when the bike is leant over onto the flat bit it will track on any road surface imperfection a whole lot more (just like wide low profile tyres do on cars) giving the horrible feeling you describe.
Old 24-08-11, 06:05 PM   #5
NedSVS
It is a bigger contact patch until you lean a little further than normal,then it rapidly gets smaller then back to normal when you reach the unused "chiken strip" - if you can get that far without falling off!
Old 24-08-11, 09:07 PM   #6
Lozzo
Reducing the steering head angle by the drastic amount you have is going to have a negative effect on tyre wear as well, because you've put so much more weight over the front and the tyre is working harder mid corner.
Old 24-08-11, 09:33 PM   #7
Biker Biggles
Biker Biggles's Avatar
I think you have described a worn out tyre.Replace it and the handling will be transformed.
Maybe I won't be riding this winter... (Tyre issues - Pirelli Diablo Rosso) D4rkr34per Bikes - Talk & Issues 11 07-12-10 08:57 AM
New rear tyre but same old one on front - any potential handling issues? Paul the 6th Bikes - Talk & Issues 18 24-11-08 05:04 PM
Front brakes - what are the common issues when changing MavUK SV Talk, Tuning & Tweaking 2 08-04-07 05:30 PM
GSXR Front End Conversion Handling Issues Mesomorphman SV Talk, Tuning & Tweaking 8 10-09-06 01:46 AM
Pillion & Front end issues TSM Bikes - Talk & Issues 15 22-07-05 11:25 AM
