Old 28-08-11, 03:38 PM   #1
liamhicks1989
Default Electrical Problem on my SV
Hi guys, just bought my first SV650s 99 today and so far very impressed but i have a problem with some electrics i hope someone could shed some light on.
Basically I have no main beam or high beam just a side light.
When i do put the main beam on the indicators illuminate (not flashing but steady glow). Also when i go to indicate the dash dies all except the rev counter and the digi display turns off and only the rear indicators flash.
** Edit** also same happens when i press the flash button the dash dies and i have no horn now :/
This is as clear as i can put it but any help would be much appriciated.
thanks liam
Old 28-08-11, 04:18 PM   #2
Default Re: Electrical Problem on my SV
Sounds like a bad earth to the front bit of the loom, pull all the connectors you can find around the front end and check for rust and fuzz
Old 28-08-11, 04:20 PM   #3
liamhicks1989
ill go and give it a go thanks, hopefully it is just as simple as an earth
Old 28-08-11, 10:01 PM   #4
liamhicks1989
Thanks so much for your reply, i couldnt see any block connectors at first untill i removed the clock surround and behold 4 big block connectors, altho they looked fine i un did them and blew them out and hey presto everything works as it should
thanks again
Old 28-08-11, 10:04 PM   #5
Electro
Give em a clean up and a little protection and you should be good for a while.
Old 28-08-11, 10:09 PM   #6
liamhicks1989
yep will do next thing on my list is to have a very thorough look over the bike tomorrow when i have more time and check everything and give it a little clean. just out of curiosity any ideas on common faults to take particular notice of
Old 28-08-11, 10:41 PM   #7
Electro
If you are going to commute on the bike if it hasnt got a front fender extender, get one. The frontspark plug can get affected by water and you end up running on 1 cylinder, there is a water drain hole nr the front plug that needs to be clear of crud. If you can use a multimeter check the voltages at the plug for the reg/rec foot brake side of the bike under the seat cowl, there are loads of threads here that tell you what to look for.
electrical problem alibax Bikes - Talk & Issues 3 08-02-11 06:26 PM
electrical problem - help! ray_mears SV Talk, Tuning & Tweaking 10 10-11-10 05:38 PM
Electrical problem MCN_LiamM SV Talk, Tuning & Tweaking 6 14-10-09 10:06 AM
SV electrical problem jonnyt SV Talk, Tuning & Tweaking 2 05-07-06 10:28 AM
electrical problem jasonsv61 SV Talk, Tuning & Tweaking 5 22-12-04 08:35 PM
