Old 30-08-11, 04:51 PM   #1
Fifteen15
Default Bought my first bike yesterday. Needs a service.
I bought my first ever bike yesterday, an SV650 K6. I need to service it, well not me, but my dad. He has a mechanical background and always services the cars. He's going to change the oil filter, air filter, and replace the spark plugs. He's also going to tighten the chain slightly because it's a bit slack. Is there anything else that needs to be done? It's only done 11k miles so hopefully wont need that much.
I need to buy the parts, and Ive been asked to get an oil filter, air filter, and 2 spark plugs. Could anyone direct me to a website (in the UK) that sells these, and/or recommend me which type/brand to get. I'm a complete beginner and this is my first bike so any help whatsoever is appreciated. Thanks
Old 30-08-11, 05:13 PM   #2
TamSV
TamSV's Avatar
Default Re: Bought my first bike yesterday. Needs a service.
First big service isn't until 15,000 miles (valve clearances) so pretty much what you've suggested plus a general check over, grease pivots etc. If he's feeling adventurous he might want to check the shock linkage and head bearings for grease as Suzuki don't like to use too much. I'd always change the coolant and brake fluid if I don't know how old it is.
The brake calipers can get a bit grotty and sieze up easily so that's worth a look/clean.
I personally use HiFlo air and oil filters and NGK plugs, which all seem to work fine. Get them from your local shop or online from ebay or the usual online suspects - M and P, B & C Express etc. For oil I use Castrol Power 1 - mainly because that's what they've got in the local shop.
Congrats on the new bike. Piccies?
Old 30-08-11, 05:50 PM   #3
carpet monster
www.wemoto.com
Or you could even go to a Suzuki dealer, consumables like filter tend to be reasonably priced (I bought a VW genuine oil filter for my golf from the dealer cheaper than the equivalent Halfords!)
Old 30-08-11, 05:59 PM   #4
Stonesie
As above, what you have said there is all it needs for a 11K service, the garage I took mine to didnt even change the air filter though, just blew it out with an air line....
Chain slack is 20-30mm with the bike on the side stand and the rear axle nut is a 24mm and torqued to 100 N:m. Be careful undoing that as the plate under the nut likes to spin with it and take a slice out of the paint, I use a long bar and "jerk" it to shock it loose when I'm feeling energetic, if im being lazy I just fire up the compressor and give it a quick squirt on the impact gun.
You MUST! re-fit the spindle (axle) from the exhaust side so the nut is on the stand side if you have it out, somone fitted it the wrong way on a mates bandit and it took a chunk out of a 1 week old exhaust can... Messy.
Old 01-09-11, 09:15 AM   #5
lx_online
For the valve clearances - what do you guys choose, dealer or DIY?
Old 01-09-11, 09:40 AM   #6
Nobbylad
Nobbylad's Avatar
Go to Hein Gericke and get 4L of oil and they throw in the oil filter free £23.99 all in. (I even got a magnetic oil filter this time around).
Get a Haynes manual which will show you how to do pretty much everything you'll ever need to in the way of servicing. That, combined with searching the forum will see you right.
For spark plugs, I use Iridium ones from this ebay seller, they also sell standard plugs too. They're the cheapest I've found for plugs => http://www.ebay.co.uk/itm/2-Iridium-...item588f01c9b5
Don't forget you'll need a new crush/copper washer for the sump plug...again you can get these from Hein Gericke (5 for £1.99) or from any car/bike mech shop.
Old 01-09-11, 09:43 AM   #7
Nobbylad
Nobbylad's Avatar
I used to go to the dealer, thinking it was one of those 'difficult, techincal, mechanical' jobs....however now I've been doing all the servicing myself since the dealer I was using wasn't even changing all the plugs on a service. I've found there's a shed load of stuff that is easy to do (incl. valve clearances) that once you've overcome the whole 'newbie mechanic' fear factor and done it once, it really is a doddle.
As long as you can read/use a torque wrench - it's pretty much plain sailing.
Old 01-09-11, 10:38 AM   #8
_Stretchie_
Large Member
_Stretchie_'s Avatar
And whereabouts are you? There may be someone nearby that can offer assistance
How to amuze an idiot:
Look right-> <-Look Left
Old 01-09-11, 10:56 AM   #9
lx_online
Sort of stealing the OP post now, sorry! I'm in Brackley - near Towcester/Milton Keynes/Northampton.
My bike is on 15,000 miles, so valve clearances are coming up. I really don't want to have to pay £400 for a service that includes this check - so I think I'm going to invest in a torque wrench like Nobbylad says.
Old 01-09-11, 12:45 PM   #10
Nobbylad
Nobbylad's Avatar
And a manual and some feeler gauges.
Spend time reading/re-reading the process and then scout around on here for tips. Don't forget that the dealer doesn't/shouldn't just do the oil/filter/plugs/valve check. They 'should' also check the fluid levels, steering head bearings and give the bike a general look over for loose stuff and anything that looks dodge.
Whether or not they all do is very subjective and dependant on the individual mechanic (and probably their workload/conscience) in most cases.
Some dealers are worth the money for the amount of time/care they will spend on your bike, others are not worth £40, let alone £400.
Well my bike was 10 years old yesterday... Viney Idle Banter 15 04-12-10 06:19 PM
so i bought an electric guitar yesterday! guitar players...how did you learn? Dappa D Idle Banter 32 16-12-08 02:51 PM
Bike had it's first MOT yesterday Giffer2 SV Talk, Tuning & Tweaking 4 05-05-08 12:23 PM
Bought my third SV yesterday! Jamie Slick SV Talk, Tuning & Tweaking 75 24-04-08 06:20 AM
Bought a new pair of trainers yesterday.... Gordon B Idle Banter 21 06-01-08 03:26 PM
