Old 31-08-11, 06:27 PM   #1
carpet monster
Default Battery at 15+ V, engine off, lights off...
... That'll be a knacked regulator then?
Old 31-08-11, 06:38 PM   #2
carpet monster
Default Re: Battery at 15+ V, engine off, lights off...
Engine off, unloaded battery ... climbed to 15.4 v
Idle, no lights ... 18 v
5,000 rpm, no lights ... 18v
Idle, lights on ... 16v
5,000 rpm, lights on 16v
Old 31-08-11, 06:40 PM   #3
carpet monster
No wonder I have to keep jump starting the bugger!
Old 31-08-11, 06:50 PM   #4
Richy_T
To be honest, with those readings, I'd suspect your meter.
Batteries generally can't put out more than 12V. It's the chemistry (six 2V cells).
Old 31-08-11, 06:53 PM   #5
Geodude
Geodude's Avatar
Have a read through this guide mate. It does sound like reg/rec kaputt but as richy t says try another meter to be sure.
Old 31-08-11, 07:11 PM   #6
carpet monster
Hmm, I will try that tomorrow, it's a bit dark now!
Old 31-08-11, 07:13 PM   #7
tigersaw
tigersaw's Avatar
check the meter on a smoke alarm battery or a car, sounds wrong.
Old 31-08-11, 07:13 PM   #8
kellyjo
Yep, check the meter. I recently changed my reg/rec and my meter showed the battery as still only charging at 12v. Borrowing a superior meter showed it charging at 14.6v!!
Old 31-08-11, 07:26 PM   #9
carpet monster
Nicked the battery from the smoke alarm, measured it at 8.5v
Old 31-08-11, 07:46 PM   #10
tigersaw
tigersaw's Avatar
Pretty much what I'd expect for a good one.
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? maxinc Bikes - Talk & Issues 5 22-07-11 02:59 PM
Battery not charging with lights on benji106 Bikes - Talk & Issues 9 02-03-11 02:13 PM
No side lights, brake lights, rear lights and dashboard lights Shona Bikes - Talk & Issues 25 13-11-09 11:07 PM
running lights direct from battery barwel1992 SV Talk, Tuning & Tweaking 2 28-09-09 05:05 PM
Display and lights flicker on tickover. Battery probs? rich_r SV Talk, Tuning & Tweaking 8 14-03-07 11:06 PM
