Old 02-09-11, 01:27 PM   #1
lx_online
Default Torque Wrench
Hi,
Has anybody got a useable torque wrench that I could buy? Struggling to get together £70 to buy a halfords pro one... Alternatively if you can recommend a cheaper one that still does a good job.
(I think the tightest one is 100Nm on the SV?)
Alex.
Old 02-09-11, 02:15 PM   #2
hardhat_harry
Default Re: Torque Wrench
I think you will have a problem with that, engineers consider a torque wrench is for life not just for xmas....
Old 02-09-11, 02:56 PM   #3
SV Mad
I got one similar to this ten years ago and it's still going strong and nowhere near £70.
http://www.tooled-up.com/Product.asp...FUcMtAodT0Qq0Q
Old 02-09-11, 07:32 PM   #4
Machine Mart or toolstation are about £30 for a 150Nm 1/2" torque wrench
Drapers are £27
Old 02-09-11, 07:56 PM   #5
Shawthing
Shawthing's Avatar
Few months ago i came across Clas Ohlson.
Torque wrench (£30) 60 TO 210Nm and Chrome Vanadium 1/2""-24mm socket (~£3)
And they have shop in Watford and other places.
SK9 Sport Black Delkevic can.
Old 02-09-11, 08:16 PM   #6
Nobbylad
Nobbylad's Avatar
http://www.amazon.co.uk/gp/product/B...ef=oss_product
Draper 34570 3/8-Inch Square Drive 10-80 nm
£23
Old 02-09-11, 08:26 PM   #7
Chris Bird
Originally Posted by lx_online View Post
Hi,
Alex.
145 nm on your front sprocket nut IIRC
Old 04-09-11, 03:56 PM   #8
lx_online
Cheers for this! I could have ended up buying the wrong wrench that maxed out at 100Nm. Hopefully my Haines manual will arrive soon so I can check all of the settings in there.
Thanks all for your recommendations as well.
Old 04-09-11, 06:09 PM   #9
muzikill
muzikill's Avatar
big torque i bought from argos. Up to 25nm i bought from screwfix.
Old 04-09-11, 09:01 PM   #10
cymroboi
cymroboi's Avatar
ive still got this in the shed doing nothing .....£60 posted mac tools
http://forums.sv650.org/showthread.php?t=166641
2003 triumph S4
2002 sv 650
cymroboi is offline   Reply With Quote
Low torque torque wrench suggestions? sam anon SV Talk, Tuning & Tweaking 3 03-12-09 09:32 PM
Torque wrench rpwoodman SV Talk, Tuning & Tweaking 7 19-04-06 12:55 PM
Torque Wrench andyb SV Talk, Tuning & Tweaking 13 16-02-06 10:43 PM
Which torque wrench ?? pepe SV Talk, Tuning & Tweaking 9 06-05-05 07:48 AM
Torque Wrench TSM SV Talk, Tuning & Tweaking 21 28-04-05 09:06 AM
