Old 03-09-11, 08:49 AM   #1
ian505050
Default SV1000 battery fit 650?
Will an sv1000 battery fit an SV650
Old 03-09-11, 09:15 AM   #2
davepreston
Default Re: dumb battery question.
will tell you when i get home tonight
but im thinking yes
Old 03-09-11, 09:20 AM   #3
ian505050
That's not good enough Dave. I need to know before 12.00. Just finish what your doing and go home early, you have my permission if anyone asks. I am thinking no.
Old 03-09-11, 10:11 AM   #4
davepreston
according to irksy its a fit ,sure worst case senario i buy it off you if it dont work
Old 04-09-11, 08:54 AM   #5
ian505050
Yer what's a good price for you Dave. It's brand new and boxed.
Old 04-09-11, 10:36 AM   #6
Depending on model an SV650 has either a YT12A-BS or YTX12-BS battery, an SV1000 has a YTX14-BS battery.
From Yuasa's website:
Curvy 650 - YT12A-BS - 150 x 87 x 105mm
Pointy 650 - YTX12-BS - 150 x 87 x 135mm
SV1000 - YTX14-BS - 152 x 88 x 147mm
So they're all the same footprint, (just about - I doubt the slight quoted difference would be noticable), but differ in height. Dependant on which exact bike you'd like to fit the larger battery to, this may or may not be a problem.
Old 04-09-11, 05:04 PM   #7
ian505050
Default Re: SV1000 battery fit 650?
Hi, thanks for all the advice, battery now replaced with direct replacement costing £45.00 which aint too bad i guess.
Anyway My YTX14-BS Battery which is a direct replacement for the sv1000 battery is up for grabs. Its brand new boxed at is for sale at £ 30 + £4.50 P+P as its quite heavy. I think i paid about £45.
Old 04-09-11, 06:20 PM   #8
davepreston
if youve still got it after i get back for germany i'll have it
all funds required for oktober fest atm
Old 04-09-11, 06:26 PM   #9
ian505050
ok, no probs, just PM me when u want it
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? maxinc Bikes - Talk & Issues 5 22-07-11 02:59 PM
dead battery - possible reg/rec + battery? collis SV Talk, Tuning & Tweaking 8 20-09-10 02:47 PM
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
