Old 07-10-11, 09:55 AM   #1
a1istair
Default Bye Bye Battery
Finally my trusty Yuasa YT12A-BS battery has given up the ghost.
It was born in the middle of Munich on a Europe trip in 2008. Following a quick 10 minute fizzing of acid it was hurredly loaded into the bike and we set off, already behind schedule. Turns out that the old battery was fine all along and the actual fault was the ol' R/R so 3 days later the battery was 100% drained and as the power cut to the instument panel, the bike spluttered to a halt outside of Venice. R/R replaced and trip completed, the battery then went on to survive everyday use in a cold UK winter before being sat in a cold shed for 2 years whilst I lived in Canada. Upon my return I was surprised to find that after a couple of days on the Optimate the top green light came on and the battery was back in business. It has even survived a rather cowboy boost start from a car booster. But now there is no electricity in my bike and the optimate fails to bring the battery back to life, it is finally time for it to be laid to rest.
Basically - I can recommend the Yuasa battery to anyone!
On another note does anyone have a heads-up for good battery offers at the moment?
Cheers,
a1istair.
Old 07-10-11, 09:57 AM   #2
LankyIanB
Default Re: Bye Bye Battery
e-bay is often worth a look. Quite a few sellers include next day delivery.
Old 07-10-11, 04:09 PM   #3
embee
embee's Avatar
Try Batteryman/Debbie at MDS (see http://forums.sv650.org/showthread.php?t=123313&page=11 for example)
Always gets good references.
Old 07-10-11, 04:21 PM   #4
chris8886
chris8886's Avatar
i used them for the second time only a few weeks ago and got excellent service once again! you must ask to speak to debbie and make sure you mention the .org and you should get a bit of discount
AR08 to AR13-QUALITY!
Old 25-10-11, 01:47 PM   #5
suzukimad123
Hi Alistair can you tell me what ol' R/R means mate please................thanks Rik
Old 25-10-11, 02:27 PM   #6
a1istair
R / R = Regulator / Rectifier
I think it's almost a badge of honour to own an SV and have to replace it at some point.
Went with a Yuasa one from ebay in the end.
I love the fizzy part when the acid is added - very exciting!
Now it works a treat. Not been able to use the bike for a few weeks but the new battery started it on Sunday without faltering.
Old 30-10-11, 06:03 PM   #7
suzukimad123
Hi mate yeah i worked it out after i got off the site its for my mates SV, i checked it out and it is the R/R thats causing the problems thanks.......Rik
Old 30-10-11, 07:13 PM   #8
Stuuk1
Absolutely recommend Debbie from MDS, amazing service and also when I was sent the wrong battery they let me keep it (it fit another sat nav of mine) and sent the correct one out next day!
I will always use them now.
I am here: http://maps.google.com/maps?ll=51.192364,0.725658
Member of the 1 litre club...
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? maxinc Bikes - Talk & Issues 5 22-07-11 02:59 PM
dead battery - possible reg/rec + battery? collis SV Talk, Tuning & Tweaking 8 20-09-10 02:47 PM
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
