Old 25-10-11, 03:53 PM   #1
krhall
Default Curious Ailment?
For the last couple of weeks I have been noticing a strange sensation at the tip of my right index finger every now and then. It keeps on feeling hot, almost burning for no apparent reason whether I am touching something or not. It isn't hot to the touch either!
Any ideas?
Old 25-10-11, 04:05 PM   #2
Bluepete
Bluepete's Avatar
Default Re: Curious Ailment?
Stop picking your nose. Your bogies have gone septic...
Not helping?
Pete
Old 25-10-11, 04:20 PM   #3
thulfi
It could be for no reason whatsoever and a benign neuropathic pain that will fade with time. I think it would be a good idea to see your doc so he can check your blood sugar levels to exclude the possibility of diabetes.
Are you experiencing any other symptoms such as blurred vision, thirst, weight loss? Have you had this before?
Have you changed anything with regards to your biking (jacket/gloves/motorcycle/lengthier journeys etc?) or any sport related activities?
Old 25-10-11, 05:07 PM   #4
krhall
Cycling 100+ miles a week recently rather than motorised transport - only noticeable change in lifestyle.
Old 25-10-11, 05:54 PM   #5
Bluefish
There you go then, Frostbite
Old 25-10-11, 06:11 PM   #6
Biker Biggles
Biker Biggles's Avatar
W&nkers cramp?
Try using the other hand
Old 25-10-11, 06:56 PM   #7
Might want to get your position on your bike (cycle) checked out to make sure thats not causing it. Get your Doc to check out the medical possibities first.
But bike postioning isn't an exact science and there are lots of different viewpoints on what is right
Old 25-10-11, 08:51 PM   #8
Jayneflakes
Jayneflakes's Avatar
Cycling is well known for damaging nerves in the hands. Make sure that your gloves are a good fit, are warm enough and have enough padding, check your grips/bar tape to make sure that there are no thin bits that could cause a pressure point. Then check position of your controls to ensure that you are maintaining the correct angle for your fingers to work at strength and not risk a damaged tendon.
If that does not cure it, see your GP for advice, you could have some nerve damage that needs looking at.
Jayne you're a Pussy Magnet
Old 26-10-11, 02:16 AM   #9
http://en.wikipedia.org/wiki/Vibration_white_finger
Old 26-10-11, 09:53 AM   #10
krhall
Originally Posted by Biker Biggles View Post
W&nkers cramp?
That'll be it then!
curious phenomena - my TV set is a radio pete m Idle Banter 13 27-05-09 09:06 PM
Curious about dyslexia Caddy2000 Idle Banter 46 27-05-08 12:29 PM
Curious Noob TheDangerousQuietOne Bikes - Talk & Issues 15 02-05-07 06:18 AM
Curious! xlewdx Idle Banter 11 05-11-06 11:33 AM
Curious Balsca Bikes - Talk & Issues 1 24-01-05 02:21 PM
