Old 25-10-11, 04:57 PM   #1
hailwood68
Default Belly Pan Fitting Kit (K7)
Hi, anyone know where I can pick up a belly pan fitting kit for my K7 at a reasonable cost? The genuine Suzuki one (990D017G70HAL) is just shy of £90 which I thought seemed rather expensive though I don't know what parts it comprises of.
Cheers!
Andy
Old 25-10-11, 09:24 PM   #2
blackknight
Default Re: Belly Pan Fitting Kit (K7)
try pyramid mine was about 40 quid
Old 25-10-11, 10:36 PM   #3
Better just making your own aluminium ones.
Left hand ones
Right hand front one, which I changed so that it's totally hidden when the bellypan is fitted
The back right one is a little more complicated because it sticks out about an inch from the engine mount bolt but you could use washers or some cut down alu pipe
Old 26-10-11, 07:57 AM   #4
hailwood68
Thanks Guys. Asking a lot but any chance you could trace me a drawing of what you have made? They look very professional I have to say!
Old 27-10-11, 08:27 PM   #5
Sorry keep forgetting about this. I'll get you the distances between the holes if you want this weekend
Old 27-10-11, 09:11 PM   #6
hailwood68
Thanks that would be appreciated.
Andy
Old 02-11-11, 03:43 PM   #7
Sorry for the wait. Here you go
Old 02-11-11, 07:11 PM   #8
hailwood68
Many thanks for very professional set of drawings if you don't mind me saying so! I reckon you've done this sort of thing before! Right rear looks a bit of a sod but lets see what we can do. Are there any other bits in the kit and what bolts / fasteners are employed please?
Thanks again
Andy.
Old 03-11-11, 12:10 AM   #9
Yeh the rear right could be tricky. I already had that standard alu one luckily.
For each hole in the fairing there should be a rubber grommit and metal sleeve to stop the bolt cracking the plastic when it is tightened. Did you not get anything with your bellypan? Bolt sizes, em I think they're all M6 and I just used ones I had in an assorted tub.
Old 03-11-11, 09:19 AM   #10
hailwood68
Smile Re: Belly Pan Fitting Kit (K7)
Thanks Again.
Andy
Fitting belly pans aaron2102 SV Talk, Tuning & Tweaking 3 30-09-08 11:46 AM
Belly Pan fitting kit mattsv1000 For Sale - SV's and SV related items 3 16-08-08 12:46 PM
Belly Pan fitting FG1 SV Talk, Tuning & Tweaking 4 24-11-07 02:46 PM
fitting a belly pan Dave The Rave Bikes - Talk & Issues 4 26-01-07 11:58 PM
Belly pan fitting kit ivantate Stuff Wanted 2 28-09-06 11:54 AM
