Old 05-11-11, 04:10 PM   #1
topfridgeman
Default 41mm emulators for sale
For sale,
1 pair of 41mm cartridge emulators, suitable for your SV. New, never fitted.
60 pounds with free postage in the UK.
Purchased for an SV minitwin project which has been shelved.
Ta.
Old 05-11-11, 04:38 PM   #2
stormingjoe
stormingjoe's Avatar
Default Re: 41mm emulators for sale
Curvy or pointy?
stormingjoe is offline   Reply With Quote
Old 06-11-11, 09:36 AM   #3
topfridgeman
I don't think it matters. As far as I know, the forks dampers/springs are the same size.
Will deffo fit the curvy forks.
Col.
Old 06-11-11, 07:35 PM   #4
It does matter, too loose in top of pointy damper rod. Doesn't sit right, you can use in pointy but you need to make a bushing.
Old 07-11-11, 04:06 PM   #5
hardhat_harry
Chris, if you give me the dimensions of the bush if a pointy buyer want them I will make them on the lathe and chuck them in with the emulators.
Old 07-11-11, 07:03 PM   #6
Robw#70
3801> carby, 4101> injected
Old 09-11-11, 07:51 PM   #7
topfridgeman
IS that the part number?
Col.
Old 10-11-11, 01:00 PM   #8
quik_d
Google tells me those codes quoted are racetechs part numbers
3801 = 38mm
4101 = 41mm the ones you appear to have?
Old 10-11-11, 06:29 PM   #9
stormingjoe
If they are racetechs that would be applicable, if not then could be these that are for curvies https://www.debrix.com/ProductDetail...ode=24-0361-VT
Old 10-11-11, 07:46 PM   #10
Those fit pointies too with spacer, don't see why OD of emu is important as long as it supports spring and seals comp chamber.
Dimension that is different between pointy/curvy is way less that 38/41mm
Racetech fork springs and emulators for sale Rick K For Sale - SV's and SV related items 7 09-10-11 01:05 PM
Racetech Emulators For Sale richiekuk For Sale - SV's and SV related items 8 24-04-10 08:45 PM
41mm forks Neeja Bikes - Talk & Issues 9 08-03-10 08:17 AM
For Sale Racetech Emulators - 03-08 SV650 + .85 Springs df1uk For Sale - SV's and SV related items 4 29-07-09 01:14 PM
Longer dogbones 41mm wow SV Talk, Tuning & Tweaking 17 30-10-08 09:28 PM
