Old 06-12-11, 02:35 PM   #1
paul123
Default curvy lower fairing fitting instructions?
Hi has any body got the curvy lower fairing fitting instructions they could post or email me as trying to make some brackets to fit
Old 06-12-11, 07:24 PM   #2
leebex
Default Re: curvy lower fairing fitting instructions?
sent you pm
Old 07-12-11, 08:45 PM   #3
myfirstsv
If you go to the TCP SA website (they were the OEM suppliers of lowers for the SV) you can download a PDF of how to fit them.
If you need new grommets in the plastic, best of luck the are a real sod to fit. Washing up liquid and swearing helps.
Old 07-12-11, 08:57 PM   #4
leebex
put rubber grommets in very hot soap water, that works a treat, as the heat softens them up
Old 07-12-11, 09:11 PM   #5
myfirstsv
Where were you when I needed you!
2 hours to fit the fairings and a bloody day getting the grommets in.
Top tip Paul, you can't get the top screw into the air intakes UNLESS you loosen the upper fairings first. And that's a load of fun as well.
Still when it's all done she will put a smile on your face cos it just looks so right. Especially if you have a seat cowl and she's pearl lively yellow.
Old 08-12-11, 07:27 PM   #6
leebex
I dont loosen the top fairing when i fit mine, way too much agro. if you loosely fit the plastic black screws for the fake air intake (the top and bottom ones) then you wont need to remove the top fairing.
Tighten them up after the button head screw is fitted behind the fake black intake, theyre only plastic and dont seem to vibrate out, although its only the top one which isnt fully tight, but finger tight.
That tip of using very hot soapy water also applies to rubber exhaust mounts for cars, but best not mention that here
Lee
Old 09-12-11, 12:04 AM   #7
paul123
looks like i am going to have some fun !! when i get some time off !!
Lower Fairing fitting kit Ally Stuff Wanted 1 22-06-09 01:37 AM
Lower fairing fitting kit. Ally Stuff Wanted 1 15-06-09 09:01 AM
Anyone got Removal/fitting instructions for upper fairing K3 Pointy? shorn SV Talk, Tuning & Tweaking 6 27-07-08 09:22 PM
2nd gen factory lower fairing install instructions? DLN84 SV Talk, Tuning & Tweaking 11 16-10-07 01:47 PM
lower fairing fitting kit d8mof Stuff Wanted 5 13-03-07 04:49 PM
