Old 11-12-11, 01:59 PM   #1
richardh
Default Pooh! metal debris in old oil.
Hello all, what a Sunday!
I've just changed the oil on my 2003 SV650s with about 45,000 miles on the clock.
I noticed the old oil looked like someone had poured a bit of cream into it and then when I poured that into a container, what a shock I got, quite an amount of metal debris sat at the bottom of the driptray. (oh pooh)
The bikes been running fine, no smoke, no noises, no nothing to indicate a problem.
Any ideas whats happened, how much it will cost me and why me?
Any help much appreciated.
Richardh
Old 11-12-11, 02:09 PM   #2
BBadger
Default Re: Pooh! metal debri in old oil.
creamy oil suggests coolant and oil are mixing.
So check the level of the radiator and expansion bottle to see if they have dropped, and check your coolant colour aswell.
If this is the case its a head gasket....not expensive if you can do the work yourself.
as to the metal, cant say as i dont know enough about it but someone will be along who does. otherwise id say the oil colour and metal are related.
Old 11-12-11, 02:17 PM   #3
Ferrous or not? Colour? Particle size? Uniform dispersion through the oil or clumps?
I think we should be told.
Old 11-12-11, 02:57 PM   #4
richardh
Default Re: Pooh! metal debris in old oil.
The bits stick to a magnet, so thats non ferrous I think. particle size is dust upto 2mm, flakey and brittle, I hope that helps.
Coolent level is fine, no change there.
richardh
Old 11-12-11, 03:19 PM   #5
If they stick to a magnet they're ferrous, i.e. steel most probably. Therefore not directly plain bearing material, but there are lots of possibilities, anything elae you can tell us?
Colour? Shiny or dull? Engine running OK, no abnormal anything?
Old 11-12-11, 03:55 PM   #6
richardh
The metal debris is dark and charcoal like and everything was running sounding fine.
If this all is beginning to sound ilogical, maybe I should drain the engine again to make sure nothing from rusty exhaust fastners etc has just fallen in the oil tray after draining first time.
that would be a relief!
Old 14-12-11, 03:24 AM   #7
monkey
He he. I very much like the sound of your latest theory.
But where did the creamy stuff come from?
Old 14-12-11, 09:30 AM   #8
richardh
The engine / oil had been warmed up but that shouldn't give it a froth!
A double check is in orderme thinks, summoning up the strength to change the oil again and dump the 2.7 litres of finest semisynthetic.
Old 14-12-11, 10:05 AM   #9
monkey
Can't you stick it straight back in if it's still nice and clean?
Old 14-12-11, 10:17 AM   #10
richardh
mmmmmm, the drip tray (washing up bowl) isnt, I'll see if I can rig something up with a plaggy bag.
Although if the oils clean with no engine bits in it, i'll fill it up with Don Perignon!
removal of debris on exhaust . hall13uk Bikes - Talk & Issues 8 16-02-08 05:18 PM
Motorway Debris Beenz Idle Banter 28 09-01-07 05:58 PM
Winnie the pooh furrybean Idle Banter 8 01-09-06 05:30 PM
Drinky pooh 24th of March? Caddy2000 The Essex Lounge 4 25-03-06 07:32 PM
why? is heavy metal called heavy metal pegasus The Essex Lounge 14 09-06-05 07:26 AM
