Old 13-12-11, 02:56 PM   #1
Spoonie
Default Sv Indicator Wiring
Ok not sure if I'm being silly (or someone else is)
But could people have a look at the connectors on there SV's for the indicators and tell me what shape they are at the back and the front?
The reason I ask is I've now broken two indicators* I ordered a rear replacement getting a front connector with it and now ordered a front replacement getting a rear connector with it.
I used two different dealers (mainly since I got the wrong part off the first one)
So are spare parts dealers a tad special or has Suzuki swapped the front and back indicator set?
I'll start the ball rolling and say that I've got a connector shaped like a circle with 3 v shaped cut outs at the front and a rectangular one at the back.
* First due to an oil patch, the Second due to avoiding an ambulance: the irony of the pain my shoulder is now in is not lost on me
Old 13-12-11, 03:03 PM   #2
SV Mad
Default Re: Sv Indicator Wiring
Sounds like you've got the standard Suzuki connectors in the bike (v shaped cut outs). An easy and cheap fix is to swap for these http://www.halfords.com/webapp/wcs/s...egoryId_255229 then you can add most indicators.
Old 13-12-11, 03:12 PM   #3
Spoonie
I'm not fussed about having standard connectors I'm just amazed that two separate spare parts dealers managed to both "get it wrong" I'm just wondering if my bike is 100% standard, or did Suzuki in some infinite swap the front connectors and back connectors?
As far as I can tell, last time when I ordered a rear right I got a front left (wrong connector and the little indent for levering it off ended up at the top not the bottom)
This time I ordered a front right and got a rear right (indent is in the right place but the connector is wrong)
Aftermarket indicator wiring? Murph SV Talk, Tuning & Tweaking 2 22-10-11 04:52 PM
Wiring a gear indicator Stu Bikes - Talk & Issues 5 25-02-10 12:13 PM
LED Indicator Wiring rob13 SV Talk, Tuning & Tweaking 5 23-01-06 08:07 PM
Indicator wiring question!! lodman27 SV Talk, Tuning & Tweaking 2 26-03-05 07:13 PM
