Old 28-12-11, 06:25 PM   #1
leebex
Default Fork oil level measurement?
Just tried the search feature, and seems my 3 and four letter words are too common again, I really must learn some bigger words!!!
Im in the middle of changing fork oil on the sv, ive removed the forks and theyre now upside down so the oil and cack can drain out. (the oil was really black and frothy)
Is it right that to fill up with new oil I simply leave the spring out, and fill to within 104mm of the top of the leg with the chrome part (stansion is it?) compressed?
Thanks, Lee
Old 28-12-11, 08:42 PM   #2
leebex
Default Re: forkin oil.
no one knows?
Old 28-12-11, 10:33 PM   #3
tim8061
Blimey it's Christmas - give us a chance!
From the SV1000 manual
Place the front fork vertically without spring .
Compress the front fork fully .
Pour the specified front fork oil into the front fork up to the top
of the inner rod .
Move the inner rod slowly more than ten times until no more
air bubbles come out from the oil .
The air-gap depends - Hagon spec different with their springs.
HTH
Old 29-12-11, 07:36 AM   #4
NTECUK
NTECUK's Avatar
I'll sort you a manual.
Comp on the curvey.
Old 29-12-11, 08:57 AM   #5
Default Re: Fork oil level measurement?
Patience, patience, patience, without the spring installed
Old 29-12-11, 09:06 AM   #6
Fork upright, spring removed, pour in roughly the right volume of oil, then slowly pump the fork leg a few times, don't do it quickly or you'll trap loads of air bubbles in the oil which can alter its volume quite a bit.
Put the fork to one side and leave it for a little while until there are no bubbles on the surface of the oil. If in doubt slowly pump the fork a couple more times and put it aside again.
When you're happy that the oil is settled, slowly compress the fork fully and then measure the oil level.
Old 29-12-11, 07:13 PM   #7
leebex
ah ha, lovely, thanks for the replies you 4. explainations and piccies thanks will do that tomorrow then.
Oil level/Air gap fork question. sath182 SV Talk, Tuning & Tweaking 19 04-11-11 04:10 PM
Fork Oil Air Gap Measurement: MrMessy SV Talk, Tuning & Tweaking 9 07-07-11 05:28 PM
fork oil capacity/ level stuballs SV Talk, Tuning & Tweaking 7 12-01-09 12:42 PM
Fork Oil level SVStu SV Talk, Tuning & Tweaking 8 19-09-07 03:10 PM
Fork Oil Level Daglad SV Talk, Tuning & Tweaking 4 02-01-06 11:35 PM
