Old 09-01-12, 09:01 PM   #1
SoulKiss
SoulKiss's Avatar
Default Plumbers/Builders, advice please.
Just stripped out the broken extractor fan in my Bathroom.
Is an old-style syrface mount Xplair DX200T - big n bulky.
This has left me with about a 6" diameter hole with a 4" ducting pipe and a chocolate block terminated (by me) set of wiring.
The new DX200T is designed to be mounted recessed into the ceiling, and is about £60.
Looking around I can see a DX100T which is much smaller and would be easy to mount, also a flush mount kind of thing and costs £20
Can I go cheap on this, or should I spring for the DX200T, the Bathroom IS fully internal (no windows) and is about 8'x6' so ventilation is rerally required.
Or is there another unit I should think about fitting?
Old 09-01-12, 09:54 PM   #2
Default Re: Plumbers/Builders, advice please.
Ive stopped fitting 4 inch fans now for people as they are only barely decent if they stay on for 15 mins after a shower or bath.
4 inch fans generally move 80 cubic metres an hour, 6 inch move 240+ metres an hour, its a no brainer really.
Im not fully getting what you're asking tbh, are you saying you dont want a 6 inch fan anymore?
Ive just fitted item 36631 in my own bathroom, works great.
Old 09-01-12, 10:33 PM   #3
$ inch fans generally move 80 cubic metres an hour, 6 inch move 240+ metres an hour, its a no brainer really.
This
The 4" we've got is hopless compared to the 8" that was originally in.
Is there the space to get the 6" duct in?
Avoid the energy saving ones they're pap IMHO
Old 09-01-12, 10:49 PM   #4
SoulKiss
SoulKiss's Avatar
Nah its 4" output or nothing, dont have access to the ducting beyond where it comes through the ceiling.
Might have to go for the new DX200T then - I think it movesa bit more air than the DX100T and the like.
Old 09-01-12, 11:50 PM   #5
You can get more effecient 4 inch fans that might move more air.
Ive just had a quick look in some catalogues i have and the highest i can find in there is 95 cubic metres an hour, so a slight improvement.
Actually, you could step it down from 6 inch to 4 inch, it will increase output pressure a bit but ultimately will move more air.
Any plumbers out there? Advice required. Tigerrrr....... Idle Banter 10 30-10-11 07:26 PM
Plumbers pls advice 600+ Idle Banter 26 29-10-09 10:23 AM
.org builders - advice/suggestions please madness Idle Banter 8 07-10-09 08:43 PM
Any builders on here? Camel Idle Banter 25 28-05-08 09:58 PM
Any builders on the site ? stewie Idle Banter 14 19-10-07 01:46 PM
