Old 13-02-12, 06:41 PM   #1
vardypeeps
Default SV650s (04) Fuel Pump same as other FI bikes?
Yo guys.
What year fuel pumps will fit my SV650s 04? I looked on svspares website but for my year bike the picture was showing a massive pump and I'm very sure it's just a small one that attaches to the frame?
Just got to find the fault listing now for when I sort a wire to check it.
Thanks in advance.
Rob
Old 13-02-12, 07:55 PM   #2
vardypeeps
Default Re: SV650s (04) Fuel Pump same as other FI bikes?
Can anyone suggest a decent type of cable to make the dealer mode wire? Just used a thin copper headphones cable but it would'nt work when across the correct terminals.
Any ideas?
I'm almost certain that it's the fuel pump relay that has gone but want to check before I spend any money as I'm broke!
Old 13-02-12, 07:59 PM   #3
MJC-DEV
MJC-DEV's Avatar
I use a bent paper clip with a bit of heat shrink to insulate all but the ends.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 13-02-12, 08:09 PM   #4
Dicky-Art
K3 and K4 fuel pump are the same. K5 looks identical but is a different part number. K2 has a petrol tap (fuel ****) no pump in the tank.
Old 13-02-12, 08:46 PM   #5
vardypeeps
Nice one thank you, will try the paperclip tomorrow.
SV650s (04) Fuel Pump vardypeeps Stuff Wanted 1 16-02-12 01:29 PM
Fuel Pump Relay DJ123 SV Talk, Tuning & Tweaking 1 08-08-11 06:54 PM
k3 fuel pump assembly widget Stuff Wanted 0 13-05-10 12:23 PM
Fuel pump cornishrider SV Talk, Tuning & Tweaking 6 02-03-08 07:25 PM
K5> fuel pump phil24_7 Stuff Wanted 11 29-10-07 05:18 AM
