Old 14-02-12, 06:33 PM   #1
gerrymcghee
Default oil leak - socket bolt next to drain plug.
can anyone tell me what the allan key socket screw is next to the oil drain bolt on my 1999 sv650 as it has started to drip oil onto the garage floor.
I am just a bit hesitant about loosening it off in order to fix it as it does not seem to tighten.
Old 14-02-12, 06:49 PM   #2
TamSV
TamSV's Avatar
Default Re: oil leak
It's just a plug for a drilling in the case mate. You can remove it OK (although be ready to catch all of your engine oil). All the swarf from the engine manufacture seems to collect in there so don't be massively concerned if it looks like there's some metal fragments in it.
It should torque up. If it won't tighten then someone's maybe had a go at it before and threaded it. I've got taps, helicoils and stuff if you need anything to attack it with.
Anyway, never mind that, not seen you round here for a while. Pint?
Old 14-02-12, 07:04 PM   #3
gerrymcghee
Default Re: oil leak - socket bolt next to drain plug.
cheers thanks for that, yeh not been around much, I've working away from home. If you fancy a pint are you doing anything this friday?
Problems with oil drain plug Grey Rider Bikes - Talk & Issues 8 19-04-10 04:32 PM
how to get the sump plug/bolt or filter bolt out without murdering someone? Paul the 6th Bikes - Talk & Issues 11 31-05-08 10:49 AM
Air Cleaner Drain Plug phizog SV Talk, Tuning & Tweaking 11 30-12-07 07:36 PM
where is the coolant drain plug?? hall13uk SV Talk, Tuning & Tweaking 34 25-05-05 04:25 PM
Oil drain plug- Help. Peter Henry SV Talk, Tuning & Tweaking 7 17-10-04 01:26 PM
