Old 26-02-12, 08:04 PM   #1
Sabarius
Default Odd noise and delay on power after gear change
So for a while now the bikes been making a bit of a fluttering noise, it's not got worse and I just figure it's a bit annoying but normal. Only mention it in case it's relevant.
Anyways to the more recent issue, this weekend I've been out twice and done maybe 100 miles or so and the fluttering has become more of a sucking/wheezing noise when the throttle is rolled on, it doesn't seem to be directly related to revs per se more the amount of gas. also I've noticed that when I change gear normally and open the throttle it takes a split second for any power to come through, if I change really slowly it's ok.
They could be related, or not. I own a Haynes manual and some spanners but that's as far as my mechanical experience goes! What should I try next to narrow this down a bit?
Thanks Org
Old 26-02-12, 08:06 PM   #2
Default Re: Odd noise and delay on power after gear change
Airbox not seated properly?
Old 26-02-12, 08:15 PM   #3
Biker Biggles
Biker Biggles's Avatar
What bike is it?
Old 26-02-12, 09:01 PM   #4
Sabarius
2004 Sv650s K4, sorry that might've helped. It's done about 22k miles too
Old 26-02-12, 09:18 PM   #5
tom-k6
could be some sort of rubbish blocking airfilter mainly or as mavi has said, airbox not seated properly,
when did you last clean the filter or replace?
Old 26-02-12, 09:49 PM   #6
Sabarius
Kk thanks, that's what I was after just a place to start looking. I'll get mr. Haynes out tomorrow and see what we find. Thanks
Old 26-02-12, 09:55 PM   #7
AZZ3R
Do one job at a time if theres a problem your just eliminiating the possibilitys first, I'd say clean the filter maybe check the Air box while your down there go run it check it come back.
When you fixate on a noise or feeling it becomes annoying, this might just be the feeling but you've cottoned' on to it more? I thought my gear changes where harsh, but after checking a couple vids there fine, I tend not to use the clutch from 40 upwards so that may have played a part.
Get a air hose or canister & spray opposit direction the filter papers sit the the filter & re-install.
or just replace the filter there only about £15 & then you know it's not that & you've replaced something that may not have been checked in them 22k miles.
Old 26-02-12, 10:22 PM   #8
Sabarius
So if you're above 40mph you don't use the clutch at all? Didn't know that was possible!
I'll check the air filter tomorrow, I've only owned the bike since December so obviously not done it myself yet. It had a full service history but I guess you never know.
Old 26-02-12, 10:24 PM   #9
tom-k6
im the same with upshifts above 40mph, dont feel the need to use the clutch, just drop off the throttle. use it going down though,
Old 26-02-12, 10:25 PM   #10
davepreston
its called a clutchless shift
use foot to apply upward pressuse to the gear lever ,get high revs, blip the thottle (off on quickly), it ups gear
Loss of Power and Knocking Noise Gabriel2k SV Talk, Tuning & Tweaking 10 09-08-11 08:54 AM
Gear change problem-can't get past 2nd gear muzikill SV Talk, Tuning & Tweaking 8 14-03-10 10:10 PM
Gear change problem-can't get past 2nd gear muzikill SV Ecosse 8 13-09-07 07:45 PM
