Old 26-02-12, 09:27 PM   #1
FahimW
Default SV650S 09 chain guard bolt stuck.
Hi All,
So I was trying to fit rear hugger on my sv650s 09 today and tried loosening all the screws/bolts on the existing chain guard but one screw, the one closest to left foot rest would not budge. Tried lubricating it and leaving it over night and tried to loosen it in the morning but still no luck.
Tried different screw drivers and socket set too but the bloody thing wold not move.
Do you guys have any suggestions?
Thanks.
Old 26-02-12, 09:42 PM   #2
HoL
Default Re: SV650S 09 Rear Hugger
How about an impact driver
Old 26-02-12, 09:50 PM   #3
tom-k6
you could try a smack with a hammer, sometimes they just need a shock to unsettle any corrosion that has set in.
other than that, you could whack out the rear wheel and try a pair of pliers on the other side of the bolt.
Old 26-02-12, 09:59 PM   #4
StitchSV
I Had the same issue with the same bolt a few weeks ago. Soaked it in WD40 but in the end I had to hacksaw a groove in to the head of the nut and the used a flat head screw driver with a gentle tap of a hammer.
After much swearing, finally got it out so new bolt news washers and some cooper grease and it's all back on.
Originally Posted by FahimW View Post
Hi All,
Thanks.
Old 26-02-12, 10:02 PM   #5
FahimW
Hi all,
Thanks for the replies...i have already tried the hammer trick to no avail.
Will try the impact screw driver and last resort will be your suggestion StitchSV...By the way...what screw did you put on to replace the existing one?
Thanks.
Old 26-02-12, 10:44 PM   #6
Default Re: SV650S 09 Rear Hugger bolt stuck.
Under no circumstances use an impact driver on that bolt - you were lucky you didn't snap the lug off the swingarm hitting it with a hammer. You luck will run out if you repeatedly larrup the little bent bit of metal welded onto the swingarm.
If the screw is now goosed drill or cut the head off, - just the head - remove the chainguard and use grips or similar on the remaining section.
But whatever you do stop hitting it.
Old 27-02-12, 07:06 PM   #7
StitchSV
Default Re: SV650S 09 chain guard bolt stuck.
I'd ordered some replacement bolts from a Suzuki dealer. The replacement has a Philips head where's one existing ones were allan key heads. The replacement did feel more solid.
They are only a few pence from the dealer. I had rounded the Allan bolt trying to get it to budge hence hence the hacksaw. Its not as brutal as it sounds.
Good luck.
Old 27-02-12, 08:55 PM   #8
FahimW
Hi All,
The impact screw driver did the trick no problem. I didn't even have to put that much force onto it.
Thanks everyone.
Remove stuck Allen bolt Mark_h SV Talk, Tuning & Tweaking 24 09-10-11 11:17 AM
Naked curvy chain guard and chain Squatepantz Stuff Wanted 0 10-05-11 07:41 PM
Stuck bolt with a difference..... arcdef SV Talk, Tuning & Tweaking 10 02-10-09 04:10 PM
Help needed, stuck crash mushroom bolt! Ash999 SV Talk, Tuning & Tweaking 6 19-05-06 10:26 PM
Stuck caliper bolt svrash Bikes - Talk & Issues 7 24-04-06 08:30 AM
