Old 01-03-12, 12:36 PM   #1
pencil shavings
Default spring weight help
hi guys,
I weigh 185lb without gear, should I be looking at 9.0N springs?
Ive searched and found the racetech calculator but it wont work for whatever reason.
I would like the .orgs view before I order and take the salesman's view as gospel.
Thanks
Old 02-03-12, 07:21 AM   #2
m`baubz
Default Re: spring weight help
9,0 might feel a bit too heavy, especially if you leave the stock rear spring.
i'm 200lbs and wish i'd gone for 8,5 as the preload dajusters are fully out
at correct sag (though it might be that i cut the spacers too long )
Old 02-03-12, 09:32 AM   #3
pencil shavings
thanks,
I have the GSXR rear to go on as well so not leaving the rear stock.
I guess .85 is a big step up from the .65 or whatever is in there so I will see what they say on the phone today
Old 02-03-12, 10:26 AM   #4
Dipper
Dipper's Avatar
I'm 175lb and have been advised .85 by the org's resident suspension guru.
Dipper is offline   Reply With Quote
Ohlins shock spring rates by rider weight ads109 SV Talk, Tuning & Tweaking 16 15-09-12 11:14 PM
rear spring and weight questions. WP shock DaveW_42 SV Talk, Tuning & Tweaking 8 10-08-10 03:35 PM
Suspension question regarding shock spring and weight monkey Bikes - Talk & Issues 6 27-05-10 01:44 AM
Spring Rate and Oil Weight? PURPLE SV Talk, Tuning & Tweaking 4 25-05-09 07:43 PM
Bar end weight Diveboy Stuff Wanted 4 07-02-06 02:48 PM
