Old 03-03-12, 10:37 AM   #1
trail guru
Default Is my k3 engine out of tune?
When I first got the bike 2 years ago mpg was around 55 mpg and engine ran smoothly. It's now does about 40 mpg, it backfires on deceleration and occasionally gives a 'cough' and conks out when slowing right down or stopping.
I first thought the drop in mpg and engine misbehaving went hand-in-hand with the engine being out of tune but I'm not sure so I have some questions for our experienced members:
1) What's the most likely cause for the above misbehaviour?
2) Is the drop in mpg likely to have another cause like brake drag, bearings? Neither of these are obvious but the rear pads have always 'rested' on the disc causing very slight drag (ie: the wheel's not totally free to rotate if you pop it off the ground).
3) Best course of action?
Bike specs are: SV650S K3; 30K on clock; Fuel exhaust; Pipercross air filter (cleaned 3K miles ago); due for 15K service; idle speed 1300rpm (warm engine).
Old 03-03-12, 06:46 PM   #2
Speedy
Default Re: Is my k3 engine out of tune?
If you have a dragging brake, that won't help.
Tyre pressures OK?
Chain and sprockets OK?
SO many little things will affect mpg.............how much did you weigh 2 years ago compared to now etc etc.
BUT. If you have a running issue, that's going to be the most likely cause.
Are the throttles sync'd? Are the plugs OK? Do you have an H/T lead breaking down?
Have you noticed a drop off in power? If you have, you will be opening the throttle more to compensate for the lack of oomph, therefore using more fuel, allbeit, that extra fuel might not be getting burnt properly.
Old 03-03-12, 08:24 PM   #3
trail guru
Thanks for replying Speedy.
Tyres pressures checked regularly and are OK.
Chain and sprockets are good (about 3000 miles old).
I'm the same weight and so's my helmet
The plugs are those that came with the bike (and should be replaced in the 15K service).
If there's a power drop it's slight. As for throttles being in sync, I have no idea. Are there any tell-tale signs I can watch for? Are they easy to check and balance?
Old 03-03-12, 08:26 PM   #4
Dave20046
Dave20046's Avatar
That brake drag sounds like a likely culprit/something that needs attention anyway
Think a symptom of unbalanced throttle bodies is rough tick over
Old 03-03-12, 09:17 PM   #5
Biker Biggles
Biker Biggles's Avatar
"Due for 15000k service"
Your symptoms are those of a bike due for a service.The 15000k one is a big service with everything done.That should show up any issues.
Old 03-03-12, 09:19 PM   #6
Joe Marcon
Wet front spark plug?
Old 16-03-12, 12:25 PM   #7
trail guru
Problem turns out to be a disconnected map sensor vacuum hose. Apparently these occasionally blow off at high revs.
I also found out it's normal for the rear pads to be just touching the rear disc.
Thanks for your help guys.
Old 16-03-12, 03:54 PM   #8
muzikill
muzikill's Avatar
Consider changing the oem hose clip to a band type clip. Most of the clips round that area are rubbish and a blow off tells me the tensions gone in it.
Name that tune DarrenSV650S Idle Banter 7 10-06-10 08:48 PM
Name that tune DarrenSV650S Idle Banter 14 19-04-10 07:00 PM
Name that tune DarrenSV650S Idle Banter 3 20-11-07 10:26 PM
tune Wideboy Idle Banter 2 04-08-07 02:00 PM
What is that tune... Anonymous Idle Banter 7 31-03-06 09:57 AM
