Old 10-03-12, 02:02 AM   #1
swamp_lifesv650
Default How much fork oil?
Ok well I need to change my fork seals. I have already bought my fork seals and dust boots.( all balls brand). Now I need to know how much oil to put in each fork leg....... I weigh 220lbs fully geared up.
Thanks in advance fellas. Robb.
Droid Incredible 2 on the move!!!
Old 10-03-12, 09:17 AM   #2
Joe Marcon
Default Re: How much fork oil?
I think u need 491ml in each leg . Just let someone comfirm this tho
Old 10-03-12, 09:41 AM   #3
muzikill
muzikill's Avatar
year/ model sv? because the levels specific. Plus, you arent using upgraded springs etc?
Old 10-03-12, 11:00 AM   #4
jambo
jambo's Avatar
500ml per leg will be enough for any SV650 fork. Depending on the springs and use you may our may not want a thicker oil than the standard 10w
Old 10-03-12, 11:30 AM   #5
timwilky
timwilky's Avatar
Do not go by a volume. You should be setting a consistent air gap.
General first start appears to be about 125mm. although I seem to recall the Haynes manual recommendations for curvys being 104mm or there abouts and 114mm for k2 with factory soggy springs. Never owning a fugly pointy thing, you need to do some research of the appropriate gap.
But whilst you got the things stripped, you weigh far more than the rice eating jap. so change your springs to something more appropriate.
Not Grumpy, opinionated.
Old 10-03-12, 11:38 AM   #6
swamp_lifesv650
Were can I get springs?? I'm still new to the upgrading lol I was goin to use 15w oil.
Old 10-03-12, 12:26 PM   #7
this might help
http://www.sv650.org/sv_manuals.htm
Old 10-03-12, 05:35 PM   #8
hongman
Contact sv650racer for a nice discount to org members on ktech springs!
Old 10-03-12, 05:35 PM   #9
hongman
Never mind just noticed location lol
Fork oil air gap DavieSV SV Talk, Tuning & Tweaking 4 28-07-09 09:58 PM
Has anyone ever heard of or seen a fork slider save a fork-track or road (Not SV!) monkey Bikes - Talk & Issues 8 28-10-07 11:59 PM
fork oil antsv650 SV Talk, Tuning & Tweaking 2 06-05-07 08:16 PM
Fork Oil tricky Bikes - Talk & Issues 2 27-07-06 08:15 AM
K4 fork spares, damper tubes,preload adjusters,fork lowers ianofbhills For Sale - SV's and SV related items 11 13-03-06 06:58 PM
