Old 02-04-12, 04:57 PM   #1
davepreston
Default Trike - higher ratio differential?
right want to up gear gems trike as first is redundant
it seems that the easyest way to do this is to change the rear diff for one with a better ratio
its a ford sierra atm and would surmise that id still need to use a sierra dif but a higher ratioed one
my question is how do i check which is in it and how would i find out which is geared higher
is there anything i could be missing here eg will i have to change the drive shaft etc
dave
Old 02-04-12, 05:03 PM   #2
orose
Default Re: trike diff
Daft question... what size wheels are you running? Bigger wheels should knock the acceleration down in favour of a higher top speed, if I remember the way we were thinking on the project in the garage.
Old 02-04-12, 05:31 PM   #3
rictus01
rictus01's Avatar
well the normal way to identify the diff ratio would be to look up the make and model and year, however that maybe a little difficult, but you should be able to find the type (shape and fixing etc) by comparison, in order to get the ratio the diff is set to, put a mark in the intake flange (where the propshaft fits) and the outlet (where drive shaft fits), rotate the driveshaft flange a complete turn and count how many (or part there of) rotations of the propshaft flange, this will give the ratio you currently have.
Cheers Mark.
Old 02-04-12, 06:15 PM   #4
might be better asking on one of those weird ford owners club forums.
what engine is in the trike?
Old 02-04-12, 07:10 PM   #5
davepreston
its a dragstar 650 engine bibio mate
Old 02-04-12, 07:51 PM   #6
Default Re: Trike - higher ratio differential?
so half bike trike and not one of those vw things.
from what i remember from my cortina/escort days it's possible to change the final ring and pinion in the diff housing. common mod with escorts.
i found this if it's any use. http://www.super7thheaven.co.uk/Sier...r_Differential
might be worth giving these people a phone. http://www.quaife.co.uk/
Old 02-04-12, 07:53 PM   #7
AndyBrad
normally the "economy" models have a higher diff ratio than the sporty stuff.
Old 02-04-12, 08:32 PM   #8
Paul the 6th
Paul the 6th's Avatar
photograph and serial or model number markings on the diff, get on www.Locostbuilders.co.uk and post said pictures along with any info you may have as to the origin of the diff...........
People on there will argue til the world ends as to which diff it is, and more helpfully will advise on a better ratio diff.
Old 03-04-12, 10:00 PM   #9
punyXpress
punyXpress's Avatar
Just SOMETIMES ratios are stamped on diff carriers.
9/27 or 9:27 would give 3 to 1
Now: Street Triple R
14/47 Front and Rear Ratio? I M Chris SV Talk, Tuning & Tweaking 6 01-04-12 03:45 PM
Trike Drifting Stenno Idle Banter 2 28-03-12 03:08 PM
Pic's of trike for those that asked:) Mrs_giggles Idle Banter 21 22-01-12 09:05 AM
Can i ride a trike? Badeye Idle Banter 7 19-10-11 06:09 PM
SV Master Cylinder Ratio TSM SV Talk, Tuning & Tweaking 12 09-11-05 12:21 AM
