Mini-Twins Goto Minitwins Official Site
Old 19-04-12, 12:04 PM   #1
Whitty
Default is turning a front tyre unthinkable.
As above, I have an sc2 supercorsa front that's chewed on right side. I have a test day at 3 sisters next week where it was chewed up originally other week. I have a tidy scrub to go on but want to save till race on Sunday as its so abrasive. Does anyone do it or is it stupid to even think it. I turn rear supercorsas regular with out trouble, I just keep it in back of my mind when cranked over.
Old 19-04-12, 12:21 PM   #2
NTECUK
NTECUK's Avatar
Default Re: is turning a front tyre unthinkable.
Has anyone you race with done the same.
Let is know how you get on if you do try it.
Old 19-04-12, 01:18 PM   #3
flymo
flymo's Avatar
if they have a 'direction of travel' arrow then no, they shouldnt be put on backwards.
You may well get away with it though, not something I would take the chance on.
Old 19-04-12, 01:39 PM   #4
DaveW_42
DaveW_42's Avatar
You can turn slicks round, but I've never heard of it being done with treaded tyres... As flymo says - if there's a direction of travel arrow - be wary. Suppose it might depend on the weather - if the tread isn't dispersing water properly or something
K4 trackbike, a black K8 S loaded with my spares and a 1989 CBR 400 TriArm with all the trimmings.
DaveW_42 is offline   Reply With Quote
Old 19-04-12, 01:39 PM   #5
Webber
Is direction of travel not mainly for the tire to clear water correctly using the tread? Other then that i couldn't see a reason why it couldn't be turned around?
Old 19-04-12, 01:50 PM   #6
Sy-superfly
All supercaorsa can be turned but only for practice days, they won't allow it in the race. The way to tell is look inside the tyre and see how the moulding is done, if it's at 90 degrees to tyre wall it's ok, if it points then no.
Old 19-04-12, 02:03 PM   #7
Whitty
All supercorsas are directional. The banding inside front and rear is kind of on a slight spiral. Not quite 45degree but not far off.
Old 19-04-12, 02:11 PM   #8
flymo
flymo's Avatar
I think the issue oi twofold. First, the tread pattern is designed to work in one particular direction. Obviously this will be most noticeable in the wet but could also affect grip in the dry.
The second important issue is the tread splicing direction, when fitted the correct way the forces acting on the tyre should not stress the join where the tread rubber was spliced together. When fitted incorrectly there is a chance that this join could fail or cause deflation.
Old 19-04-12, 03:49 PM   #9
twowheels
i have done a day at cartagena with a turned supercorsa, it was fine for me..
..but i would never race on it, just TDs / Test days etc
Old 19-04-12, 06:08 PM   #10
Whitty
Front or rear?
Front tyre for gsxr 750 front end on the SV? payner123 SV Talk, Tuning & Tweaking 13 31-05-11 07:25 PM
GSXR front end swap - front tyre profile. Khewett SV Talk, Tuning & Tweaking 12 11-05-06 11:24 AM
NEW Front tyre: BT 020 Flamin_Squirrel For Sale - SV's and SV related items 6 16-02-06 06:05 PM
Front tyre and can you mix front and back makes? creamerybutter Tyres 9 12-05-05 08:38 PM
Front tyre and can you mix front and back makes? stick Bikes - Talk & Issues 4 04-01-70 03:19 PM
