Old 20-04-12, 01:58 PM   #1
hongman
Default Is engine oil flammable?
If someone asked you this, what would you say?
Someone in the office asked this today. I immediately said no.
Googel was then consulted and we found a flashpoint figure of 400-480F.
So does this mean it is technically flammable?
Old 20-04-12, 02:01 PM   #2
Default Re: Is engine oil flammable
you can burn it in a special oil heater I think.
An old motorcycle garage used to have one in their workshop to heat it in the winter using old engine oil
I reckon my diesel would run on it as well
Old 20-04-12, 02:08 PM   #3
eeerrrrmmm did you not watch the gulf wars.....
Old 20-04-12, 02:27 PM   #4
He's too young to remember that
Old 20-04-12, 02:53 PM   #5
hongman
Old farts
Old 20-04-12, 02:55 PM   #6
punyXpress
punyXpress's Avatar
There've been cases ( ? Berlin ? ) where turbo seals have blown & engines have run away because of oil being leaked into the diesel engine. Cut the fuel off & engine oil becomes the fuel!
Which is a worry
Now: Street Triple R
Old 20-04-12, 02:55 PM   #7
Nobbylad
Nobbylad's Avatar
Wow...I never realised that Iraq stored huge quantities of used engine oil underground...I always thought it was naturally occurring crude oil
Old 20-04-12, 03:00 PM   #8
johnnyrod
johnnyrod's Avatar
Yes oil burns, but it needs some persuasion. Flash point is the temperature above which it will burn, once ignited. It's not the temperature it ignites by itself - that's the auto-ingition temperature and will be much higher. Anyway normally flammable means flash point near or below room temperature e.g. petrol, solvents. For diesel it's about 100C i.e. putting a match to it will put the match out if you are below 100C, but it still gets labelled as flammable, I think that's more to do with fuel regs than anything (not sure).
Old 20-04-12, 03:01 PM   #9
Whitty
Which is a worry
Happens a lot in buses and trucks. Volvos can be prone to it. Sometimes can happen if you only just change turbo. All previous past oil is trapped in intercooler waiting to attack! When it happens its spectacular.lol
Old 20-04-12, 03:02 PM   #10
johnnyrod
johnnyrod's Avatar
Turbos are HOT!
Engine parts and a complete engine for sale as well as other curvy spares EssexDave For Sale - SV's and SV related items 10 23-01-12 08:41 AM
Engine oil change - 5 months no engine starting sv650sfan SV Talk, Tuning & Tweaking 2 04-03-11 08:10 AM
Engine Breaking? Hopefully not. Engine braking - is that OK? butterick99 SV Talk, Tuning & Tweaking 14 12-09-09 10:31 PM
flammable, inflammable which is correct? timwilky Idle Banter 13 17-08-09 08:28 PM
Engine braking... any hazzards engine wise? John 675 SV Talk, Tuning & Tweaking 21 28-03-08 07:20 PM
