Old 21-04-12, 11:51 AM   #1
Georgekp123
Default Pointy low compression.
Hi,
I put something up a while back about my bike basically not starting, found the problem to be bent valves.
Anyway, I've now put new valves in (that I've grinded in), used new head gaskets, new stretch bolts, and made sure the timing is what it should be (not making the same mistake twice). So, I get it all back together, go to start it... Nothing.
Compression test is literally reading next to nothing in both cylinders - I can crank it over by hand with the spark plugs in!
I have this horrid feeling the piston rings are dead, but I can't work out how, as they were working fine before I started the work, and the pistons haven't been out of the barrel.
Any ideas?
Cheers,
George.
Old 22-04-12, 11:12 AM   #2
embee
embee's Avatar
Default Re: Pointy low compression.
Valve clearances??
Old 22-04-12, 12:52 PM   #3
Georgekp123
All within spec
Old 22-04-12, 03:11 PM   #4
TSM
The Sick Man
TSM's Avatar
check you have timed up correctly, it seems that your valves are not fully shutting, you could try turning the engine over 'by hand' without the cams in as that would make sure all the valves are closed.
Old 24-04-12, 01:54 PM   #5
Georgekp123
I can confirm that the timing is definitely perfect, having just checked for the millionth time.
Old 24-04-12, 02:43 PM   #6
flymo
flymo's Avatar
remove plugs, give it a squirt of oil into the cylinders and try again. If it makes no difference then it wont be rings. Also, with the law of troubleshooting, always look at what was changed first.
Do you have a compression tester?
Old 24-04-12, 03:31 PM   #7
Georgekp123
You've beaten me to it, I was just about to post that I've done that this afternoon and nothing changed :S
Yeah I do have a compression tester
Shims are correct sizes, clearances are within spec, timings are spot on, valves were replaced and grinded in (I had my ex's father come round and help sort these out so I highly doubt there's anything wrong with them due to his experience), new head gasket, new cylinder head (stretch) bolts, new oil seals, new springs, new retainers, new cotters, new spark plugs, new fuel, new coolant, new oil.
I just... Don't have a clue anymore
George.
Old 24-04-12, 03:58 PM   #8
flymo
flymo's Avatar
whip the cams out and check for compression. Just a thought, when the valves were ground in, did you leak test them with some fuel?
Old 24-04-12, 04:05 PM   #9
Georgekp123
I'm probably not going to be able to get back at it until thursday now, but I'll definitely give that a go then and let you know.
Yeah, no leaks at all, unlike before
Rear Cyl compression low. hardhat_harry SV Talk, Tuning & Tweaking 21 21-11-10 10:20 PM
compression kingy916 SV Talk, Tuning & Tweaking 3 30-01-09 02:48 PM
Low compression, possible causes? bikedoc SV Talk, Tuning & Tweaking 8 26-01-07 07:19 PM
Movie compression lukemillar Idle Banter 7 08-08-06 11:05 AM
Low Engine Compression CamScooby2 SV Talk, Tuning & Tweaking 2 02-06-05 10:52 AM
