Old 24-04-12, 11:35 AM   #1
Dunn-y
Default Adjusting chain on side stand?
Is it frowned upon to adjust your chain slack whilst the bike is on the side stand, given that the wheel is already aligned properly.
When I had my rear tyre puncture repaired they aligned the wheel on a paddock stand with quite a bit of slack and then adjust the slack with the bike on the side stand. Seemed to work as the wheel was still aligned and only took 1 minute to get the correct amount of slack and tighten the axle ready to go.
Old 24-04-12, 11:40 AM   #2
timwilky
timwilky's Avatar
Default Re: Adjusting chain on side stand
Many will say it is the recommended method.
Not Grumpy, opinionated.
Old 24-04-12, 11:40 AM   #3
MJC-DEV
MJC-DEV's Avatar
The method given in the SV handbook is to use the side-stand.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 24-04-12, 11:41 AM   #4
Dunn-y
That's good then. I'll start doing it that way, seems a lot easier. Thanks
Old 24-04-12, 11:57 AM   #5
Cymraeg_Atodeg
I adjust the chain on a side-stand then check the tension when the bike is on the side stand. Pop it up and down.
If you want to get really technical you should do it while you’re sat on the bike, but, I don't know anyone who can check the tension on their chain while being on the bike and keeping all their weight on the seat.
Anyway, you have 10mm of le-way, so, as long as it is less than 35mm and more than 25mm you can’t be too far out
Old 24-04-12, 08:54 PM   #6
Default Re: Adjusting chain on side stand?
Yep side stand always works for me
Adjusting chain cringer Bikes - Talk & Issues 8 11-06-10 04:09 PM
Anyone got a left side rear set and side stand? Dhayn Stuff Wanted 6 17-08-09 10:08 AM
Why do some people say you should only adjust your chain whilst on side stand? timwilky Bikes - Talk & Issues 44 08-06-09 10:53 AM
Adjusting the chain without a paddock stand? TheShadow Bikes - Talk & Issues 25 07-05-08 05:09 PM
Storage: Side stand or rear paddock stand? Maudster SV Talk, Tuning & Tweaking 19 20-01-07 04:45 PM
