Old 07-05-12, 08:50 PM   #1
HopefullySoon
Default Curvy Intermittant Spark
Hi
Hope the 'org can help me out a bit here .
I'm on an extended motorbike tour in Portugal and Spain and my bike has developed a fault with the ignition system somewhere whereby sometimes it will fire first press of the button and yet other times turns over but wont attempt to fire .
I have got 12.6/7/8 volt at both ignition coils on the orange/white wire and I've cleaned up all the connections to the coils , changed the rear coil/HT lead / plug cap (not the plug itself tho as its only done 1400 miles) , I've unplugged the CDI/ECU/brain thingymebob cleaned the terminals as best as I can and replugged it in and still have the same intermitternt fault .
Bit lost on where to go from here .
TIA
HS
HS
Old 08-05-12, 07:23 AM   #2
MJC-DEV
MJC-DEV's Avatar
Default Re: Intermittant Spark
Are you sure its not a fuelling issue ie is it hot and high altitude?
Are the starts random or first of the day etc?
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Curvy Minitwin which spark plugs? a.oneill45 SV Talk, Tuning & Tweaking 4 24-12-10 09:05 AM
No Spark - curvy. Scrappyracer SV Talk, Tuning & Tweaking 6 02-08-10 08:59 PM
Intermittant Starting Problem Owenski SV Talk, Tuning & Tweaking 0 23-07-09 12:20 PM
Intermittant starting issues thedonal SV Talk, Tuning & Tweaking 2 10-01-07 10:15 PM
