Old 07-06-12, 09:44 AM   #1
acting_strange
Default Right side indicators not working - Curvy.
Hi all
My R/H indicators suddenly stopped working last night. Bulbs ok. Any ideas gladly accepted.
L/H work fine
It's a 99' curvy BTW....
Ta Muchly
Derek
Old 07-06-12, 09:50 AM   #2
rictus01
rictus01's Avatar
Default Re: Indicators
was it both RH one's or just one of them? if just one is the other flashing faster ?
Cheers Mark.
Old 07-06-12, 09:55 AM   #3
acting_strange
It's both.....no led either for R/H....power problem?
As I said L/H works perfectly...
Not really what I wanted on my first observed ride....lol
Old 07-06-12, 10:10 AM   #4
TamSV
TamSV's Avatar
LH working OK and everything out for RH rules out a few things.
I'd look at the switch first. Open up the switch housing and clean/inspect the contacts. If that doesn't sort it check for a break in the wiring for the RH indies from the switch to the loom - light green wire I think.
Old 07-06-12, 10:14 AM   #5
acting_strange
I was afraid you would say that....sigh....oh well I will keep my fingers crosed for dirt...
Thanks Tam
Old 07-06-12, 10:14 AM   #6
rictus01
rictus01's Avatar
Yeah as Tam says, it might be worth turning the bike on without starting the engine and listening for the flasher relay, if (as I suspect) you don't hear it on the righthand side, but do on the left; then the problem is between the switch and the relay.
Cheers Mark.
Old 07-06-12, 01:46 PM   #7
acting_strange
Ok...so I've stripped the switch and the power is leaving the back side normally.
This would suggest to me either a faulty indicator/flasher unit or a broken/corroded wire.....grrrr
Can anyon now tell me how to get the front seat off so that I can get to the battery/flasher unit area please?
Many thanks again
Derek
Old 07-06-12, 02:22 PM   #8
muddydude
Undo the bolt on both side panels,remove the side panel and there is an allen key bolt remove either side and the seat will lift off..reverse for fitting m8 ..the relay is there
Old 07-06-12, 02:31 PM   #9
TamSV
TamSV's Avatar
As above. There should also be a little plastic fairing clip on the underside at the rear of each of the side panels. Push in the centre and the clip can be removed.
Old 07-06-12, 03:13 PM   #10
acting_strange
Thanks guys )
Headlight not working, indicators on permanently. frankie77 SV Talk, Tuning & Tweaking 9 21-04-11 09:00 PM
Indicators not working properly. 999birdie SV Talk, Tuning & Tweaking 3 15-10-10 05:19 PM
Fitted new indicators - not working. devil1 SV Talk, Tuning & Tweaking 3 03-04-10 05:24 PM
New indicators fitted - not working right. wilky007 SV Talk, Tuning & Tweaking 8 21-02-09 04:31 AM
Both right side indicators not working ;( drefraser SV Talk, Tuning & Tweaking 22 05-11-07 09:58 PM
