Old 07-06-12, 08:46 PM   #1
AlexW
Default Carb SV Cutting out at idle when warm.
Had my SV a couple of weeks, Had been sat for a while previously. Its a '00 SV650S. I've had a quick search but couldn't find anything with the same symptoms
Right from the start taking it to the MOT, when warm, pull the clutch in or stop and let the bike idle and it cuts out, Only when warm, when cold it has no problem idleing, even off choke.
Carbs have been cleaned, Bike has done around 800 miles in my ownership and the problem hasnt got better or worse (Not that I thought it would).
Its just like when you pull up, revs drop to idle and its like the kill switch has been flicked. Starts straight back up afterwards, and doesn't die if you pull the choke on a little or hold the revs up.
Any help would be great.
Thanks in advance.
Old 07-06-12, 09:38 PM   #2
flymo
flymo's Avatar
Default Re: Carb SV Cutting out at idle when warm
dirty carbs (most likely in my view), incorrect float levels, incorrect idle. vaccum leak somewhere (looked for cracked or perished hoses/mounting rubbers)
Old 07-06-12, 11:26 PM   #3
Sticking choke plunger.
Old 08-06-12, 12:09 AM   #4
embee
embee's Avatar
Default Re: Carb SV Cutting out at idle when warm.
As they say above, also what is the basic idle speed set at when it will idle? Should be 1300rpm or thereabouts, some people prefer slightly higher (1400).
If it'll idle when cold but not hot it tends to suggest overly rich mixture (as you get with sticky choke plunger).
Old 08-06-12, 06:46 AM   #5
flymo
flymo's Avatar
Good call, didn't think of that.
Old 08-06-12, 04:39 PM   #6
AlexW
Cheers guys, Will go through the suggestions.
Don't think it has any air leaks, Ive sprayed some cleaner stuff without any rev increase/decrease and I've replaced the vacuum hoses along with a couple of the fuel hoses.
It idles around 1300 I'd say. Messed around with the idle screw, although it messes about. Noticed it misfires once, then twice, then cuts out, So does make me believe its carbs rather than ign like I was originally thinking.
Is there any other symptoms of a sticking choke plunger, The choke seems to work ok, I'll give it a go anyway. Any reccommended way to clean it?
Cheers very mucho.
Old 20-06-12, 02:18 PM   #7
AlexW
Just to update this thread.
Pulled the choke plungers and they were fine.
Put new plugs in and it solved the issue for a few days, so now believe its a weak spark.
I'm going to try some new coils on it unless anybody can suggest anything else.
Very late edit, if somebody else finds thread, new coils fixed it
Cutting Out, won't run at idle. gwarner SV Talk, Tuning & Tweaking 6 04-03-11 01:13 PM
idle cable at carb end forklift SV Talk, Tuning & Tweaking 11 24-05-09 08:09 PM
High idle when warm K2 lpjones SV Talk, Tuning & Tweaking 3 22-09-08 11:02 AM
Carb syncing at 4000RPM not Idle!?.. kciN SV Talk, Tuning & Tweaking 19 11-05-06 02:08 AM
tyre warm up v's engine warm up? twotime SV Talk, Tuning & Tweaking 25 14-07-05 11:06 PM
