Old 22-06-12, 02:08 PM   #1
svken
Default Pointy not charging battery.
Rolled into local gas station last week after 200 mile ride and 01 SV650 with 54k miles wouldn’t re-start. Dead battery, would barely make starter motor go uuugh. Got a friend to help me load it on a trailer and on home. Turned out the battery was okay after re-charging. Charging system wasn’t working. Did various tests as per manual. My el cheapo volt meter doesn’t seem to be able to read Ohms in the 0.2-0.55 range; that, or there's is a direct short. Reads zero, absolute continuity. Five-six years ago I replaced (working OEM) RR with an ebay 7 wire Hayabusa RR. I taped off two of the battery connects and soldered the other two onto the connector. It now occurs to me that this may have created a weak current feed to the battery thus stressing the generator. Not sure, but I think it might be better to connect each of the two like wires to #10 copper wires and run straight to battery. Anyway, as near as I can tell RR is okay. Generator output not okay: check between poles 1-2 at idle 9.6 ac amps, 2-3 idle 20.2 amps, 1-3 18.6 amps. 1-2 @5k rpms 19 ac amps, 2-3 @5k rpms 71 ac amps, 1-3 @5k rpms 71 ac amps (connector looks like this -- ||, called –- as #1 pole, shouldn’t matter). Removed stator, shows some burn, overheating on coil(s) near pickup coil. Pic also shows spot where very thin covering material is worn, scraped off pickup coil pole – don’t think this is a problem.
http://s167.photobucket.com/albums/u...1stator006.jpg
I’m not very good on electrical. So, anyone have experience with after market stators. I’ve found Rick’s on ebay, Accel 152483 on Amazon, and Regulator/Rectifier.com. All are about the same price $130. Am also thinking I should replace the RR (to regulate/rectify doubts about it). Maybe should spring for a new FH008 MOSFET type. Any advice, recommendations, comments most welcome.
Old 22-06-12, 03:11 PM   #2
flymo
flymo's Avatar
Default Re: Not Charging Issues
you tried here http://www.electrexworld.co.uk/cgi-b...rch&PR=-1&TB=A
Brand new stator for £55.
Old 22-06-12, 04:14 PM   #3
svken
Default Re: Pointy not charging battery.
Thanks for reply flymo; I'll check them out. Shipping to US is often prohibitive. Need to update my profile to show location.
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? maxinc Bikes - Talk & Issues 5 22-07-11 02:59 PM
Battery Not Charging MONOLITH Bikes - Talk & Issues 11 13-10-10 10:21 AM
Charging the battery pben47 SV Talk, Tuning & Tweaking 19 09-02-10 06:56 PM
Charging a Battery DarrenSV650S Bikes - Talk & Issues 5 27-04-08 05:19 PM
Charging/Battery: MrMessy Bikes - Talk & Issues 8 30-11-07 12:50 PM
