Old 24-06-12, 07:29 PM   #1
unclepoo
Default Roadside tyre repair kits?
Has anyone tried the tyre repair kits available, I`ve seen the you-tube videos of people repairing there own tyres....are they a long term fix or just a get you home.
Old 24-06-12, 07:52 PM   #2
Default Re: Tyre repair kits?
Anything that can be done with the tyre on the rim is a temporary repair only. The maker will specify a much reduced speed limit, and often a limit on the distance they should be used for as well. I know that both of those have been much exceeded without problem on a a number of occasions, but it must be remembered that when a permanent repair is done the tyre should be inspected internally to ensure that a repair is suitable, and that the structure of the tyre isn't compromised by damage caused by the puncture, and of course that can't be done when using an external repair.
There's nothing wrong with temporary repairs - I always carry the sticky string type as I find them the most effective type - but they have their limitations and that should always be kept in mind.
Old 24-06-12, 07:56 PM   #3
rictus01
rictus01's Avatar
Default Re: Roadside tyre repair kits?
Yes used just about every type myself, prefer the sticky string tyre myself, they are only rated as a temporary or "get you home" fix with speed and distance restrictions, however if you'd asked how long and at what speed the do actually work then the answer would have been different.
Cheers Mark.
Old 24-06-12, 08:09 PM   #4
unclepoo
sticky string ?? Is that the same as the thing that looks like a rubber worm I`ve seen, they use a hand tool to push it into the tyre, then cut the excess off.
Old 24-06-12, 09:06 PM   #5
They look like this:
And are inserted with a tool that looks like a big darning needle with a handle like a screwdriver or sometimes a tee handle, the latter are quite big so the I prefer the former as it fits under the seat more easily.
Old 24-06-12, 11:22 PM   #6
Well I can testify that they work, rictus done one for me on my sprint with just 1500 miles on the stock tyres, I never did get a proper repair as I wanted to see how long it would last, I ended up doing another 2.5k including a track day.
I think it does depend where it is though too, mine was in the recess in the tread so it was protected a bit.
Old 27-06-12, 02:10 PM   #7
tomskthewomble
Only problem with the temporary repair kits is that you can't get the tyre permanently repaired after you have used one, I think!
Old 27-06-12, 02:11 PM   #8
rictus01
rictus01's Avatar
and who in their great wisdom told you that....
Old 27-06-12, 02:38 PM   #9
Airwolf
i must add that i have used the sticky strips on a car tyre with no problems.
as my car comes with no spare excepted, repair liquid which is horrible.
used the strip, and did a good few thousand miles.
never had to use it on the bike yet, but only ever heard good things about it.
Old 27-06-12, 03:05 PM   #10
tomskthewomble
I think it was a friend of mine who owns a bike shop which specialises in tyres.
Tubeless Tyre Puncture Repair Kits - BARGAIN - Have peace of mind Hooligan For Sale - Other Bikes and General biking items 13 17-02-10 11:43 AM
Puncture Repair kits ivantate Ancillaries 18 22-06-09 08:05 AM
Punctuate repair kits? squariegoes Hardware 2 03-06-09 09:23 PM
tubeless repair kits £12.99 kwak zzr Bikes - Talk & Issues 3 01-03-07 05:43 PM
Roadside Tyre Repair I'm_a_Newbie Bikes - Talk & Issues 14 16-05-06 05:06 PM
