Old 25-06-12, 01:12 PM   #1
Irish ek
Default Will these bar ends fit?
i lost one of my oem bar ends a few weeks ago and cant seem to find any oem ones online. anyone have any recommendations? only looking for one. failing that i will just buy them off ebay. i think any 7/8 inch (22mm) bar ends will fit clip ons on a K5 SV650S. will the following work?
http://www.ebay.co.uk/itm/BIKE-IT-UN...item484559acb4
if so, how exactly do they fit?? cheers.
Old 25-06-12, 02:59 PM   #2
Default Re: will these bar ends fit?
Those won't fit, as the OEM bars have a threaded insert inside, which will prevent the expander of those bar ends going inside far enough to fit.
Part number for the bar end is 56200-04821 £21 for a new pair, without the screw!
http://www.robinsonsfoundry.co.uk/co...15&submit.y=17
These are nicely made and come with the screw!
http://www.ebay.co.uk/itm/OBERON-SUZ...ht_3281wt_1110
Old 25-06-12, 10:27 PM   #3
Irish ek
Default Re: Will these bar ends fit?
thanks for that, those oberon ones state they will only fit upto a K3 SV. i might just give robinsonsfoundry a ring tomorrow, have had good dealings with them in the past! pity aftermarket ones are hard to come by, these cost a small fortune!
Old 26-06-12, 06:08 AM   #4
I'm sure Oberon make bar ends for all years of SV, the clip ons haven't changed much, if at all between years
Old 26-06-12, 05:23 PM   #5
Barty_b0y
i got some shiny solid stainless ones of ebay long time ago now but about £15ish
reason i went weighty (ie stainless instead of plastic/ alloy ) the weight is there apparently to reduce the harmonic ossilation induced upon the handlbars during the high rev ranges forced upon the engine.
So yer they do help kill vibration
Just a thought when considering plastic or metal. the originals are solid steel if i remeber right
Old 27-06-12, 10:35 AM   #6
If you haven't ordered any, here's another pair, sellers doing black or silver
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ht_1805wt_1344
Old 27-06-12, 11:09 AM   #7
where do you get the idea that pointy S bar ends are screw fitting. unless i had different bars on mine they are bung fitting so any of the aftermarket ones with a rubber bung will do.
Old 27-06-12, 08:24 PM   #8
rowdy
rowdy's Avatar
From what I can remember the bar ends on my k3 were screw fitting lance, although I've had the gixxer front end on a while now and can't remember 100%.
What I can remember though is that they wouldn't fit my TL clip ons. I did fancy a set of those oberon ones in stainless steel, but the listing says they fit sv650 and tl1000s and I don't think they will.
The Pro Bolt ones have different part numbers for sv and tl so that confirms it for me, just a pity that pro bolt don't do stainless steel ones.
Daviesv (I think) off of here used to make some lovely bar ends, don't know if he still does though.
Old 30-06-12, 11:43 AM   #9
Shawthing
Shawthing's Avatar
As you can see from the picture the OEM barend rubber expanders are ~60mm inside the bars, and so if you think they are purely screw fixing you have left the threaded rubber expanders inside the handlebars (when they can/do come out).
SK9 Sport Black Delkevic can.
Bar ends newts924 Stuff Wanted 1 21-02-10 09:51 PM
New bar ends LK-SV SV Talk, Tuning & Tweaking 1 01-02-10 06:10 PM
Bar ends? SUPERSTARDJ01 Bikes - Talk & Issues 0 27-10-09 07:00 PM
Bar Ends gone! 808OR Bikes - Talk & Issues 5 16-10-09 08:15 PM
Screws for Bar ends/ bar ends, black screen K3 Pointy renman8957 Stuff Wanted 3 06-02-09 06:08 PM
