Old 29-06-12, 07:36 PM   #1
Littlepeahead
Littlepeahead's Avatar
Default Spyball alarm help!
Just had the most random phonecall from a colleague. Her flatmate is on his BMW R1100 in the alps an the Spyball alarm has decided to immobilise the bike. So he's stuck 2 days from anyone who can help.
Any ideas oh mighty org? I know that isn't a lot of info to go on!
PM me if you can assist!
Old 29-06-12, 07:51 PM   #2
suzukigt380paul
Default Re: Spyball alarm help!
from my limited expeience of alarms not knowing to what extent a spyball alarm is wired in,id say cut it out and chuck it away,and check for link wire to get it running again,coz there is one thing for certain you can say about bike alarms(after market ones in anycase)they will let you down one day,ive got 3 bikes that had once had alarms and no longer have them,two where taken of buy previous owner and one taken of my bandit 12 by me when it let me down
Old 29-06-12, 11:31 PM   #3
rictus01
rictus01's Avatar
if as I suspect the rider hasn't the knowledge to know where to look, they aren't going to be able to remove it and retain a working bike, I'd suggest they do the basics, check for an inline fuse, all the plugs are clean and plugged in properly and the remote battery is in good shape.
Old 30-06-12, 12:12 AM   #4
Remote battery first, does he have the alarm code? It's on a blue credit card sized bit of plastic, and is used to disarm the alarm without the remote, it's a bit fiddly to use, but it will work if the fob has failed.
I don't think the 'rip it out' suggestion is very sensible, there may be no problem other than a battery, butchering the wiring at the roadside is most unlikely to improve the situation.
Old 30-06-12, 01:24 AM   #5
suzukigt380paul
but if it aint the battery or loose wire and the alarm is broke then tracing the wiring to ignition then makeng a link wire to reconect the ignition circuit should work,afterall it is a bmw R1100 and the elecric's should be straight forward,and most of the wires on the alarm go to things like the indictors(4wires)little red light(2 wires)live feed and earth(2 wires)and 2 wires to the ignition,on my suzuki the wire to the coils was near the rear light and the link wire was remove and then connect to the alarm,i know it only sounds simple after youve managed to remove one your self in the past but i doubt it will be that difficult,and it only looks daunting if you dont trace where the wires go and what they all do,and i suspect if the battery in the remote is dead then you will need the code to get it to work again and that can sometimes be as difficult to put in as takeing the alarm off,of cause theres always the unplug it and plug it back in fix that work on some electricail products
Old 30-06-12, 08:19 AM   #6
NTECUK
NTECUK's Avatar
Some times warming the remote will give the battery a boost enough to send the signal.
Out side interference from phones etc can block the code .
hold it close to the unit.
Spyball alarm problem rwoodcock01 SV Talk, Tuning & Tweaking 0 08-05-11 02:49 PM
Which alarm? loonytoon SV Talk, Tuning & Tweaking 17 01-01-11 10:42 PM
Anyone got an alarm on their SV? cbay Bikes - Talk & Issues 25 02-02-10 04:30 PM
What alarm? hybridcrip Stuff Wanted 4 11-08-09 04:09 PM
My alarm. Scoobs Bikes - Talk & Issues 4 06-02-06 07:33 PM
