Old 22-07-12, 05:34 PM   #1
I M Chris
Default Pointy Starting issues
hello pro's
rode for an hour this morning to a local Halfords for cleaning accessories, came out to start the bike and no power was coming from the battery - nothing on the display and no starting up whine...
i got bumped her fine **** down the road and as i was riding around 40-45mph keeping the revs up, the speedo said 150mph -160mph and kept going crazy lol, after 30 seconds the speedo corrected itself.
anyway i got home and she sometimes starts fine, and sometimes has no power from the battery... the battery is pumping out 12.6 so it seems fine.
any ideas guys?
Old 22-07-12, 08:45 PM   #2
DJ123
DJ123's Avatar
Default Re: Pointy Starting issues
12.6 is low, battery should be kicking out 13v, 13.2v max when charging.
BMW F800ST
Old 22-07-12, 08:52 PM   #3
chezvegas85
are you sure it wasn't something you picked up from halfrauds? i hear that tart gets about
Old 22-07-12, 09:00 PM   #4
I M Chris
I only picked up wheel cleaning gubbins.
12.6 should be enough to power the display? right? i mean nothing happened when i turned the key.
Old 22-07-12, 09:27 PM   #5
ophic
ophic's Avatar
12.6V is fine. Have you checked for loose fuses?
Silver SV650SK3, Fuel exhaust
Old 22-07-12, 09:32 PM   #6
monkey
How are the battery connections?
Old 23-07-12, 07:11 AM   #7
Shawthing
Shawthing's Avatar
Intermittent power/nothing.
Sounds like it could be the 'Green' connector problem.
Ignition barrel to loom connector.
Search 'Green Connector'.
SK9 Sport Black Delkevic can.
Old 23-07-12, 09:30 AM   #8
jambo
jambo's Avatar
I'd start here. Loose battery terminals give both a lack of power, and lack of stable power causing the speedo to move around. Check the connections at the battery, the main relay, and the earth strap to the engine (follow the +'ve & -ve wires and check the other side is tight too)
Be careful when tightening the +ve terminals as if you touch the frame with the tools, you'll create a load of sparks.
Jambo
Old 23-07-12, 05:49 PM   #9
I M Chris
Solved
Can a forum mod close this please?
Main Relay issue, big thanks the Jambo, I owe u a pint..... Godlike powers, this forum has.
Old 23-07-12, 06:05 PM   #10
monkey
What was the issue?
Starting Issues? RizlaSV Bikes - Talk & Issues 5 12-10-11 10:56 AM
Starting issues fredrickman SV Talk, Tuning & Tweaking 1 29-09-11 10:12 PM
Starting Issues robstark SV Talk, Tuning & Tweaking 2 05-02-10 01:55 PM
Starting Issues c_noble SV Talk, Tuning & Tweaking 6 15-03-07 01:48 PM
Starting issues (as in it won't...) littlewhitedaisy SV Talk, Tuning & Tweaking 1 23-06-06 09:42 PM
