Old 14-08-12, 08:29 PM   #1
Rich_hawcutt
Default Curvy running on one cylinder.
Hi, been having problems with my y model 650, a week ago it started dropping down to one cylinder, usually half way round a junction or somewhere equally useful, now it is constantly running on one. had the carbs off and cleaned the jets, all fine, fuel pump is supplying loads of fuel, that spark plug is sparking and the air filter looks fine, worried its something internal now, any ideas gratefully received, thanks
Old 14-08-12, 09:17 PM   #2
rictus01
rictus01's Avatar
Default Re: Curvy running on one cylinder.
have you checked the "usual suspects" yet?
although possible; it's not normally a mechanical cause, check out water ingress first, electrical continuity, fuel & air , then if all that is correct, valves and then move on to compression testing.
Cheers Mark.
Old 15-08-12, 10:43 AM   #3
embee
embee's Avatar
plus check choke plungers are properly free in the carb bodies, return springs are good and no sign of corrosion/gunge in the cables.
Curvy rear cylinder not running. benparker SV Talk, Tuning & Tweaking 8 15-04-12 11:12 AM
Running on one cylinder. Dunn-y Bikes - Talk & Issues 11 03-09-11 08:59 PM
SV running on one cylinder. garynortheast Bikes - Talk & Issues 3 20-08-10 01:40 PM
Too much oil on the K&N, now running on 1 cylinder... Troy Bikes - Talk & Issues 26 24-07-08 06:21 AM
1 cylinder running Scoobs SV Talk, Tuning & Tweaking 6 11-02-05 10:05 PM
