Guildford Massive For the Guildford Guys N Girls.
Old 17-08-12, 05:30 PM   #1
DJ123
DJ123's Avatar
Default wanted-Lock Nut removal tool for Swing Arm
09940-14940 suzuki number
Hey all, need a peg socket to remove the swingarm. Anyone got one I could borrow, or any tips?
TIA
BMW F800ST
Old 17-08-12, 06:03 PM   #2
Thunderace
Default Re: wanted-Lock Nut removal tool for Swing Arm
Give us a pic, or a size, the tool for removing Renault sump nuts is similar and I have many in varying sizes.
Old 17-08-12, 06:43 PM   #3
DJ123
DJ123's Avatar
http://www.ebay.co.uk/itm/SWINGARM-P...-/200557211414
Appreciate it if you have one mate
BMW F800ST
Old 17-08-12, 06:59 PM   #4
If you've got a grinder, you can cut an old socket down
Old 17-08-12, 07:06 PM   #5
Thunderace
Sorry mate biggest I've got is 28mm, also if you have a grinder,a big one like a 9", you could use the spanner that removes the disk!
Old 17-08-12, 07:41 PM   #6
Curvy or Pointy
Old 17-08-12, 08:05 PM   #7
Fallout
Fallout's Avatar
Say what?! I am going to change my chain and sprocket soon. Will I need to take the swing arm off with one of these badgers?
Edit: Actually, ignore that. I got a chain crimping woodamaflip tool, so I suppose I just split and reconnect the chain.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 17-08-12, 08:42 PM   #8
Thunderace
Exatamundo! If you remove the swingarm to replace the chain and sprockets you're far too keen!
Old 17-08-12, 08:54 PM   #9
DJ123
DJ123's Avatar
Curvy or Pointy
pointy.
Cutting a socket is my last resort ideally. Trying other avenues 1st. I am hoping that soaking it in plus gas over night will help to loosen it off and any rust. Will Be fun trying to reassemble it looking at the drawings
BMW F800ST
Old 17-08-12, 08:57 PM   #10
Thunderace
Originally Posted by daddyjob View Post
pointy.
Wouldn't cut a socket mate, it'll be as strong as a starved kitten and sounds like a recipe for grazed knuckles to me!
Swing arm removal with abba stand? DavieSV SV Talk, Tuning & Tweaking 5 12-06-09 10:16 PM
Chain buffer removal requires swing arm removal :-( 2mths SV Talk, Tuning & Tweaking 1 09-07-07 09:19 AM
tool for removing swing arm and engine fat_brstd Stuff Wanted 6 08-05-07 12:00 PM
Tool for swing arm removal? Sir Trev SV Talk, Tuning & Tweaking 5 27-06-05 04:18 PM
Fuel cap lock removal Sudoxe SV Talk, Tuning & Tweaking 4 10-04-05 03:34 PM
